kiwiaudio Posted June 7, 2007 Share Posted June 7, 2007 Every once in a while when pulling away from a stop, my ABS resets with the same racket as an initial startup. Could my battery be getting old, or do TADT? Link to comment
Joe Frickin' Friday Posted June 7, 2007 Share Posted June 7, 2007 Every once in a while when pulling away from a stop, my ABS resets with the same racket as an initial startup. Could my battery be getting old, or do TADT? 1100's, TADT. The ABS computer calls for a systems check every (I think) ten minutes; after that ten minutes is up, it has to wait until you come to a stop and then start rolling again. So it could actually be an hour or two, if you're droning down the interstate, and then get off at an exit; then it'll squeak-chirp-clunk as soon as you come to a stop and turn onto the crossroad. Link to comment
smiller Posted June 7, 2007 Share Posted June 7, 2007 TADT, but are you sure about the 10 minutes thing? My bike has performed occasional (based on what I don't know) on-the-road ABS tests since it was new but it doesn't happen all that often, and certainly not every time I continue on from a freeway exit (after at least 10 minutes run time), etc. I don't know what algorithm the thing uses to determine when it should test but it doesn't seem to be strictly time-based as far as I can tell. Unless I am having an unknown problem with my ABS that is, but I don't think so because the initialization and test cycle works properly after each re-start of the bike and the ABS system seems to be operating normally. Link to comment
John Dickens Posted June 8, 2007 Share Posted June 8, 2007 Mine does exactly the same and has done from new. No pattern to it that I can spot. Link to comment
