Firefight911 Posted June 5, 2007 Share Posted June 5, 2007 Is it merely a simple open/close switch? In particular, I am referring to the Baehr switch but I would assume that they are all the same. Looking at using the standard handlebar switch housing for the GSA and using one of the unused ABS, Info buttons to activate B2B. You know me, always looking for that clean look! Figured I would ask here before I go about destroying a perfectly good switch. Link to comment
Heck Posted June 5, 2007 Share Posted June 5, 2007 Figured I would ask here before I go about destroying a perfectly good switch. Hey, it's just another hour of OT........ Link to comment
DonSydney Posted June 5, 2007 Share Posted June 5, 2007 Should just be a 'momentary on' switch. Have just had to have a lead made up to connect my TX3400 to the Autocom, and the guy that did it for me explained it as simple momentary on..... Link to comment
bakerzdosen Posted June 5, 2007 Share Posted June 5, 2007 You know me, always looking for that clean look!Yes, but you would then have to work on the stenciling to accurately describe the function of the switch instead of just "ABS". (You know me, never anything helpful but always sarcastic. ) Link to comment
W8NONU Posted June 5, 2007 Share Posted June 5, 2007 It is just a momentary on switch. You can get several differnt types of them at Radio Shack for another option. Link to comment
sundaeman Posted June 5, 2007 Share Posted June 5, 2007 Generally a PTT switch is a momentary single pole single throw (SPST) switch. Serious variety at the link. Smorgasbord of switches Link to comment
Limecreek Posted June 5, 2007 Share Posted June 5, 2007 I installed the BMW Police PTT. It is a nice clean and sturdy solution that you might want to look into. It is designed to fit the RT, but should fit all of the late model BMWs with similar switch gear. I'll post the part number when I return to Austin. Link to comment
TechDirector Posted June 5, 2007 Share Posted June 5, 2007 I have been using a semi-custom Avcomm bike to bike system. They have a nice little push to talk switch available in both chassis mount and with velcro. Best price I have found it through Sampson Racing. To see it click here It is terminated with a switchcraft plug that may be easily unscrewed to get to the cable ends. Might be a little less than the BMW switch - which on the old RT-Ps was a PVP switch as I recall. Good luck! Chuck Link to comment
