nottooold Posted June 4, 2007 Share Posted June 4, 2007 Hi there,New to this site so hope im doing this the correct way. I have a 2003 1150rt and have some problems that i hope you can help with.I have no indicators or hazard lights working.I have only just bought the bike and it was not working when i had it.Hope you can help.All the best Hywel Link to comment
Bprimm Posted June 4, 2007 Share Posted June 4, 2007 Hi there,New to this site so hope im doing this the correct way. I have a 2003 1150rt and have some problems that i hope you can help with.I have no indicators or hazard lights working.I have only just bought the bike and it was not working when i had it.Hope you can help.All the best Hywel What is in common with the two items not working is the "flasher unit". Remove the seat and plastic cover for the fuse/relay box. Flashers seldom fail so pulling the flasher and then reseating may give a good connection once again. If not, you'll have to use the VM and find where the current isn't....switch, fuse, flasher etc. Link to comment
