Dean123 Posted June 4, 2007 Share Posted June 4, 2007 Hi, I tried to find an answer to this most basic question, but was unsuccessful. I need to get at the battery of my '04 RT. I am going to install an accessory power cord. How do I get to the battery? Thanks. Dean Link to comment
NoHeat Posted June 4, 2007 Share Posted June 4, 2007 1. Remove the left side tupperware, which requires first removing the seat and the lower tupperware. The only tool required is an Allen wrench. After removing the left-side tupperware you will see the battery slightly to the front and below the seat. 2. Unhook the rubber strap that holds the battery down. There might also be a drain tube (approx 6 mm OD) for you to pull out of the battery. Then, slide the battery out of its tray by pulling it toward the left side of the bike -- the cables should have enough slack to get the battery out this way, unless aftermarket add-ons fastened to the battery terminals have too little slack. Link to comment
DavidEBSmith Posted June 4, 2007 Share Posted June 4, 2007 And you need to remove the mirror pod, which you do by striking it from rear to front. And when you get to the battery, remove the negative cable, which is the one on the left (outer) side, and then you will be able to slide it out and get to the positive cable (and can safely remove the positive cable without danger of sparking to the negatively-grounded frame). Is it an Allen wrench or Torx on the 2004? Whichever, it will be obvious when you start removing screws. Link to comment
DonSydney Posted June 4, 2007 Share Posted June 4, 2007 Tip..... inexpensive electric screwdriver with appropriately sized allen head bit, if you're going to be removing the tupperware more frequently..... dc Link to comment
eddd Posted June 4, 2007 Share Posted June 4, 2007 Tip..... inexpensive electric screwdriver with appropriately sized allen head bit, if you're going to be removing the tupperware more frequently..... dc Tip #2: Buy a set of T-handled allen wrenches. Link to comment
Couchrocket Posted June 4, 2007 Share Posted June 4, 2007 Another tip... the REAR MOST upper screw - ISN'T A SCREW IT IS A QUARTER TURN FASTENER THAT JUST LOOKS LIKE A SCREW. It stays in the Tupperware. Take care not to break it. Link to comment
MichiganBob Posted June 4, 2007 Share Posted June 4, 2007 Tip # 3 , I like a thumb ratchet with a 3mm allen socket. Good feel so you can snug but not overtighten. Bob Link to comment
BFish Posted June 4, 2007 Share Posted June 4, 2007 And you need to remove the mirror pod, which you do by striking it from rear to front. And when you get to the battery, remove the negative cable, which is the one on the left (outer) side, and then you will be able to slide it out and get to the positive cable (and can safely remove the positive cable without danger of sparking to the negatively-grounded frame). Is it an Allen wrench or Torx on the 2004? Whichever, it will be obvious when you start removing screws. my 2004 uses torx. Link to comment
kcscout Posted June 4, 2007 Share Posted June 4, 2007 2. Unhook the rubber strap that holds the battery down. There might also be a drain tube (approx 6 mm OD) for you to pull out of the battery. Then, slide the battery out of its tray by pulling it toward the left side of the bike -- the cables should have enough slack to get the battery out this way, unless aftermarket add-ons fastened to the battery terminals have too little slack. Cool... I just learned something. Didn't know it slid out. I thought I'd have to remove both sides and tank just to get to the battery. Is this type of stuff in the owner's manual? Link to comment
Dean123 Posted June 5, 2007 Author Share Posted June 5, 2007 Fantastic information. Thanks everyone. Dean Link to comment
