Davey Posted May 31, 2007 Share Posted May 31, 2007 I have an 800S but I know that the R12RTs also have the tire pressure control. In the past on my RT, RS, and R, I have taken the wheels off and bought tires over the internet and had the local Honda dealer mount the tires. Do I need to worry about them messing the tire pressure control up? If I thought they would, I would just go to the BMW dealer although the tires and mounting would cost a lot more. Thanks. Link to comment
LuckyLeif Posted May 31, 2007 Share Posted May 31, 2007 As long as no one hits the TPM unit inside the wheel perimeter with a tire iron, I don't see any problem. I'd be sure to mention to the mechanic that you have a pressure monitor in the wheel. Link to comment
Firefight911 Posted May 31, 2007 Share Posted May 31, 2007 As long as no one hits the TPM unit inside the wheel perimeter with a tire iron, I don't see any problem. I'd be sure to mention to the mechanic that you have a pressure monitor in the wheel. +1 to that. If you look at the rim there is a sticker on them indicating the location of the sensor. Link to comment
