1057 bulb replacement?
Steve Kolenda
Steve Kolenda
Have a burnt out turn signal on my 2000 R1100RT and am having a very hard time finding a 1057 bulb, is there a more common bulb that will work? I'm assuming that the 1057 is a lower wattage than standard bulbs.
Do you know what the difference is?
I think glass sphere size. The 1057's glass bulb is smaller that the 1157's.
Jerry Johnston
Was the turn signal on the 2000 a dual element bulb? On the older 96+ rt's the bulb was a 1056 single element.
Jerry Johnston
It isn't on the 96 but I can't honestly tell you on a much newr bike. If it was a problem I would think you could solve it with a resistor across the hot lead to the ground connection.
