TowJam Posted May 30, 2007 Share Posted May 30, 2007 Old news: On the canbus equipped beemers, you can turn off the headlights by holding down the signal cancel button for 5 seconds then immediately holding down the right turn signal for 5 seconds. No news here. But on the ride home from work today I was bored and discovered that apparently the latest software updates this so that instead of having to "reboot" your bike to get your low beams back, you can simply toggle the low/high beam switch to enable the headlights and turn off the lampf! warning on the display screen. Apologies if this already old news. Link to comment
Stir Posted June 1, 2007 Share Posted June 1, 2007 Have you been running from the cops again? Old news: On the canbus equipped beemers, you can turn off the headlights by holding down the signal cancel button for 5 seconds then immediately holding down the right turn signal for 5 seconds. No news here. But on the ride home from work today I was bored and discovered that apparently the latest software updates this so that instead of having to "reboot" your bike to get your low beams back, you can simply toggle the low/high beam switch to enable the headlights and turn off the lampf! warning on the display screen. Apologies if this already old news. Link to comment
