Marilyn Posted May 28, 2007 Share Posted May 28, 2007 Has anyone added a second accessory plug to their 1200ST? If you have added one or two could you tell me where you installed it and take pictures if possible. Also, who sells them? Did you leave the original plug connected to the Canbus and wire the second plug directly to the battery? I understand that heated clothing (mine's Gerbing) will shut off if plugged into the canbus plug. Thanks. Link to comment
Paco Posted May 28, 2007 Share Posted May 28, 2007 Marilyn, I use the Powerlet socket and harness on my (CANBUS) R1200RT, wired directly to the battery so that it cannot interfere with the CANBUS system. These harnesses are available at BMW dealers or direct from Powerlet (see link) http://www.powerletproducts.com/products/bmw_ican_harness.php Link to comment
Firefight911 Posted May 28, 2007 Share Posted May 28, 2007 I added one to mine. The attached link will walk you through what I did. I did leave mine connected to the CANBus by way of a BMW piggyback set-up. As you will see in the link, I used permanent controllers for heated gear, etc. My Widder vest worked fine through the stock accessory plug but my Gerbing jacket shut it down. Here you go: LINKY Link to comment
BobsST Posted May 29, 2007 Share Posted May 29, 2007 I have four now. Two on CANbus and two direct to the battery. Three of them are clustered around the preload knob and one is in the flat tupperware panel under the clutch lever that I use for the GPS. Link to comment
Marilyn Posted May 30, 2007 Author Share Posted May 30, 2007 I have four now. Two on CANbus and two direct to the battery. Bob, what do you use the CANbus sockets for, and also the direct battery sockets? I'm trying to decide which way to do my electric stuff. Thanks! Link to comment
1hawkrider Posted May 31, 2007 Share Posted May 31, 2007 Has anyone added a second accessory plug to their 1200ST? If you have added one or two could you tell me where you installed it and take pictures if possible. Also, who sells them? Did you leave the original plug connected to the Canbus and wire the second plug directly to the battery? I understand that heated clothing (mine's Gerbing) will shut off if plugged into the canbus plug. Thanks. Hi Marilyn. I just did some wiring on mine. There is a two pin connector, intended to be used for a second accessory plug, already installed on the bike. It is directly behind the existing socket and is taped to its wiring. You may have to remove the left rear fairing to access it effectively; which means 1st removing the lower front fairing and then the upper front. Your local dealer should be able to help with the other "half" of the connector and a socket. Regards, Lou Link to comment
