Bud Posted May 28, 2007 Share Posted May 28, 2007 Going back to Ouray for a week in early August and would like to take some video from the bike. Have a digital camera that will take video but it eats batteries quickly and the quality isn't that high. Would like something that doesn't require a lot of fiddling/patching to make work. Not having a large budget for this completely unnecessary expense, what do you recommend? Link to comment
MarkEngland Posted May 28, 2007 Share Posted May 28, 2007 Bud, I mounted my video camera on my BMR shelf and get about 60 minutes of video if I run on batteries (I also have a 12v power cord). Anything more than 60 minutes I have to replace the tape also. I bought (I know you have a small budget) a new camera that is really small and lightweight and has worked well. My last camera was larger and I found the video from the digital camera did not come out very well (at least for me). Here is a link to my install: http://www.kc6tew.com/modifications/rtmods/videomount/videomount.html Here is another link to all the video I have taken. Keep in mind I’m neither a professional video guy nor an expert with Pinnacle Studio; but I have lots of fun. http://www.kc6tew.com/videolinks/videolinks.html Link to comment
Dances_With_Wiener_Dogs Posted May 28, 2007 Share Posted May 28, 2007 I'm interested in the power cable you made or was made for you Mark. The link was dead on your site. Sounds like a perfect setup...keeping the camera running and pushing the record button without battery loss. Link to comment
W8NONU Posted May 29, 2007 Share Posted May 29, 2007 My set up is very similar to what Mark has shown. I mounted my (Canon $300) relatively inexpensive digital video camera directly to my dash shelf. I went to the hardware store and got a screw the same size as a tripod mount and drilled a hole through the shelf. I also bought a nut for the screw to hold the camera tight against the shelf. Then I made a very expensive hand tightening device for the screw. I forced a nickel into the head of the screw to make it easy to tighten and loosen without tools. I take video through the windshield and it works fine unless you are riding into the sun. There I pick up some glare, but you may get this without the windshield also. I carry a small power inverter in my tank bag to recharge the battery as needed while riding. I can also use this setup to record while riding if needed. I know Tom, "azkaiser" used to use a small digital camera that had video option and was able to get about 30 minutes of video on the memory card. Where there is a will, there is a way. Good Luck with your project. Link to comment
St0nkingByte Posted May 30, 2007 Share Posted May 30, 2007 I can recommend this unit: http://www.amazon.com/Oregon-Scientific-ATC-2K-Waterproof-ActionCamera/dp/B000F5FKHI For $99 it's hard to beat. Its a once piece unit that records to SD Memory cards (same as you buy for your digital cameras), runs on AA batteries and connects to your computer with a standard USB cable. This means you don't need to invest in extra specialized gear, accessories, etc to play with video on the bike though I would recommend using rechargeable AA's because it is a bit battery hungry. I got about an hour of video on a 2gb SD card and the batteries last about as long. The video quality is OK, right about what you'd expect for $99. It does 640x480 @ 30fps and looks decent unless there is really heavy bouncing then it looks a little bit like you're underwater. If I could characterize the video quality I'd say its like a computer webcam without the computer. It comes with a reasonably good set of straps and a decent mount however I would beef up the strap and/or zip tie it before you ride because...unfortunately for me I dropped mine on the highway at high speed and it was run over several times before I could retrieve it but if I can get the missus to forgive me for blowing 99 bucks on it I probably will buy another! Link to comment
