NitoDub Posted May 26, 2007 Share Posted May 26, 2007 I have an ST for two years and have been unimpressed with it's reliability. It let me down four times and had to go back to the shop. Is it worth trading for an RT. Any issues with that bike? Link to comment
ShovelStrokeEd Posted May 26, 2007 Share Posted May 26, 2007 In that it is the same motorcycle with a different skin and even more fiddly electronic bits, how can you consider it an upgrade? Link to comment
Roger_R Posted May 28, 2007 Share Posted May 28, 2007 Really?????? I ride my ST everyday, never let me down. What kind of problems are you having? I second that they are the same bike but different skin. Link to comment
NitoDub Posted May 28, 2007 Author Share Posted May 28, 2007 I ride my ST every day as well. The battery has been replaced three times under warranty. The dealer says I am not using the bike enough to keep it charged. I find that hard to believe as the bike is used every day. For some reason which BMW are unable to adequately explain, the battery is not being fully charged. I know of two others with similar problems. I connect the bike to a charger every evening but I feel I should not have to do this. Link to comment
NakedRider Posted May 29, 2007 Share Posted May 29, 2007 Something is draining the battery. I've had mine for two years and 18,000 miles. I, too, had a dead battery once but the bike had been sitting for quite some time (I had two other bikes then). I would have the dealer check it out. Something much be creating a drain. Link to comment
TowJam Posted May 29, 2007 Share Posted May 29, 2007 Something is draining the battery. I've had mine for two years and 18,000 miles. I, too, had a dead battery once but the bike had been sitting for quite some time (I had two other bikes then). I would have the dealer check it out. Something much be creating a drain. Wasn't there some type of battery drain issue that was addressed with a software update last year? Link to comment
Firefight911 Posted May 29, 2007 Share Posted May 29, 2007 Something is draining the battery. I've had mine for two years and 18,000 miles. I, too, had a dead battery once but the bike had been sitting for quite some time (I had two other bikes then). I would have the dealer check it out. Something much be creating a drain. Wasn't there some type of battery drain issue that was addressed with a software update last year? Yes there was. The current update (v7?????) resolves this issue. Link to comment
jsmith Posted May 29, 2007 Share Posted May 29, 2007 Anyone know what the drain was coming from? It feels like my bike is not re-charging as well as it should, but not sure if its worthwhile to get the s/w update. Jim Link to comment
R4ND0M_AX3 Posted May 30, 2007 Share Posted May 30, 2007 Anyone know what the drain was coming from? It feels like my bike is not re-charging as well as it should, but not sure if its worthwhile to get the s/w update. Jim The ECU was staying powered. Link to comment
