bmwdavid Posted May 25, 2007 Share Posted May 25, 2007 What is the proper sequence for the oil lever sensor reading on the dash? I just had my sensor changed and the computer updated. The dash used to read while riding. It ow only reads when I come to a stop. Is this normal for the 06 and 07 models with the updated oil level sensors? Also noticed my temperature readout now reads way high, it was 86 and was now reading 104. Thanks Dave Link to comment
LuckyLeif Posted May 25, 2007 Share Posted May 25, 2007 My 07 indicates oil level only when engine is warm and in neutral. I believe the latest updates are similar. No problems with my temp accuracy other than it appears to be stuck on a given reading -- cycling thru the entire OBC range frees the temp and you can see it step up/down in 10 seconds. Link to comment
JayW Posted May 25, 2007 Share Posted May 25, 2007 Also noticed my temperature readout ... now reading 104. Dave An Inconvenient Truth Link to comment
gettysburg Posted May 25, 2007 Share Posted May 25, 2007 Also noticed my temperature readout ... now reading 104. Dave An Inconvenient Truth I read somewhere that Al Gore "invented" global-warming. Link to comment
Pictou Posted May 26, 2007 Share Posted May 26, 2007 What you describe for the oil sensor is normal. Mine did the same thing when I had the oil level sensor fixed (including software update). For what its worth it never did measure oil level while you were riding. Although you could see it while moving all it was doing was displaying the last reading it took while at a standstill. Link to comment
bmwdavid Posted May 26, 2007 Author Share Posted May 26, 2007 Thanks to everyone for the replies. Link to comment
Bob_Mc Posted May 30, 2007 Share Posted May 30, 2007 My '05 RT DOES check oil when I'm riding, at least when it is low. It shows a symbol that looks kinda like a dip stick. It also shows up under hard acceleration when my oil is less than completely full. Link to comment
