City Lids Screw Size
JohnNorCal
JohnNorCal
Ok, I searched but I couldn't find....
What size machine screws should I use when I drill out the rivets to mount the city case lids?
Well...when I installed the Kugler Klamps on mine...
His instructions use a M5 x 8mm, which is tapped into the hinge. So, you'll need something a little smaller.
Which makes sense, since he includes M4 which go through the hinges, and into the saddlebags to fasten there. M4x16mm for the city cases, and M4x20mm for the touring and extra-large.
BTW, I highly recommend his system. Pretty easy to install (once you get the rivets out!), and makes switching lids very easy.
Kugler Klamps
