GordonB Posted May 20, 2007 Share Posted May 20, 2007 An '01 RT w/ 21,000 miles; Checked svc records, all dlr maintained, original owner. My question is about the (dino) oil changes performed every 6,000 miles with almost 2yrs time between changes, is that harmful to the engine (the time factor)? It seems the bike didn't sit, just didn't get out much. Link to comment
g_frank_nin Posted May 20, 2007 Share Posted May 20, 2007 If you think that’s bad… I just bought a 99' R1100R with only 1700 miles , I had the same concerns as you, also, also had additional concerns with perhaps some of the gaskets and/or rubber seals drying out because of lack of use and other problems related to non use… (like rust in inside the cylinder walls for example) but so far the only problem I’ve had was a clogged fuel filter, replaced it and the rubber hoses… bike is running just fine… Link to comment
T__ Posted May 20, 2007 Share Posted May 20, 2007 An '01 RT w/ 21,000 miles; Checked svc records, all dlr maintained, original owner. My question is about the (dino) oil changes performed every 6,000 miles with almost 2yrs time between changes, is that harmful to the engine (the time factor)? It seems the bike didn't sit, just didn't get out much. Gordon, no way to really tell without an engine teardown.. If the bike wasn’t stored with high acid or moisture content oil then no problem.. If the oil was full of combustion acid or moisture there is always the chance it slightly etched the crankshaft, camshaft, cyl walls, or other engine metals.. If it was run regularly with little usage each time probably no damage done as the oil will hold up pretty good (it’s long sitting without usage that hurts) If the oil was changed before storage or the bike was stored inside or in a warm moisture free environment then probably no problems.. Twisty Link to comment
Dan Gleebitz Posted May 20, 2007 Share Posted May 20, 2007 When I bought my RT, it had done 18k miles in 5 years .... regular 6k miles servicing etc ... no problems / leaks ... no oil top ups between services now ... get on and ride Link to comment
eddd Posted May 20, 2007 Share Posted May 20, 2007 I would not be concerned in the least. 21,000 miles would be considered high miles for many 2001 bikes. Link to comment
glwestcott Posted May 22, 2007 Share Posted May 22, 2007 Buy it and I'll trade you for my 2001RT with 76000 miles on it! Link to comment
harleyjohn45 Posted May 23, 2007 Share Posted May 23, 2007 my R2000RT had 2800 miles when i bought it last december. it runs perfect. i will take a low milage bike every time and wear it out myself. Link to comment
