knock from engine
davie
Hi when I start my bike from cold my engine is fine after about 20sec there is a knock at idle from the left hand side it lasts for about a minute.
I have adjusted the rocker arm play and fitted the new cam chain tensioner.any other ideas my bike is a 03 R1150RT
with only 14000 miles.
Davie
It's the cam chain slapping until its tensioner pressurizes. There is an update tensioner that solves it, but is really only an annoyance issue. Doesn't hurt anything.
Maybe, only maybe, it could be the pushrods.
The ends become loose,and can knock until they get some heat - BMW have since changed the design .
Old design, showing the problem
Old design, with new design alongside
Davie
Davie, are you sure you installed the UPDATED cam chain tensioner parts & not just the stuff from the 1100/1150.. The parts you need are from the BMW 1200 engine..
1ea)--13541341797 Throttle body "O" ring (optional)
1ea)--07119963308 seal ring
1ea)--11317656922 piston
1ea)--11317688629 cylinder
Twisty
