jojo Posted May 18, 2007 Share Posted May 18, 2007 what do you use for lubing the throttle cable? does it have to be replaced on a regular basis? thanks Link to comment
SWB Posted May 18, 2007 Share Posted May 18, 2007 what do you use for lubing the throttle cable? does it have to be replaced on a regular basis? thanks RT (and probably RS, GS, and other modern BMW's) have teflon coated cables (or so I've heard). They should be left dry. I found some lub near the end of the clutch cable, in the clutch handle, but that's about it. I just replaced throttle cables, the junction box, the throttle advance, and the clutch cable, which was probably a bit extreme. But the response feels like new; it was worth the cost in my book. Link to comment
hopz Posted May 18, 2007 Share Posted May 18, 2007 SWB, I think I need to replace the Throttle Cable on my R1100R... what was the PITA factor involved in this job? Link to comment
Driveshaft Posted May 18, 2007 Share Posted May 18, 2007 what do you use for lubing the throttle cable? does it have to be replaced on a regular basis? thanks I use graphite lube. It's dry. You can usually pick it up at a bicycle tune shop if noone else has it Link to comment
BARTMAN Posted May 18, 2007 Share Posted May 18, 2007 FYI, I just had the throttle cable replaced on my 02 RT; 56K miles- cost $373.00 @ dealer AND WORTH EVERY PENNY!! I was "told" by another rider that the dealer(Not Mine) replaced the cable on a 02 RS under a recall notice- anyone know about this ?? any info greatly appreciated! Link to comment
hopz Posted May 18, 2007 Share Posted May 18, 2007 There WAS a recall notice on the R1100R, but I do not know when it expired. It MAY have been a Service Advisory rather than a government advised Recall. This is all speculation. I only know that during my research on my R11R it came up. Link to comment
Ken H. Posted May 18, 2007 Share Posted May 18, 2007 what was the PITA factor involved in this job? Depends upon your ability of course, but it's within reach of a good DIY'er. Short version - There are three cables, one from the grip to a junction box (called a Bowden box) located under the battery tray, and one from it to each of the two throttle bodies. Removal of the tank is required to access the Bowden box which once the cables to the throttle bodies are disconnected will slide out from under the tray to the right side of the bike. After it is all back together re-sync of the throttle bodies is required. Link to comment
Jim VonBaden Posted May 18, 2007 Share Posted May 18, 2007 what was the PITA factor involved in this job? Depends upon your ability of course, but it's within reach of a good DIY'er. Short version - There are three cables, one from the grip to a junction box (called a Bowden box) located under the battery tray, and one from it to each of the two throttle bodies. Removal of the tank is required to access the Bowden box which once the cables to the throttle bodies are disconnected will slide out from under the tray to the right side of the bike. After it is all back together re-sync of the throttle bodies is required. Agreed! I certainly wouldn't pay a dealer over $300, but then again, I do all my own work. If you have the money, and prefer not to do it, let the dealer, otherwise, it isn't that hard to do your own. As for lubing the cables. They are sheethed in nylon, and lube will cause them to break down internally. BMW specs NO lube except on the tipe to ease rotation of the ends. Jim Link to comment
Big D Posted May 23, 2007 Share Posted May 23, 2007 I replaced mine about six months ago along with the junction box with about 44K miles on the RT. Bought the cables online and did it myself. I am not a "motor head" and it was not difficult to do once the plastic is off. It was well worth the cost and the bike feels like new. Do a search on the board and you can find some help suggestions. D Link to comment
ninermatt Posted May 23, 2007 Share Posted May 23, 2007 I replaced mine roadside, lots of fun! Link to comment
hopz Posted May 23, 2007 Share Posted May 23, 2007 Can you, (well maybe you can, but can a regular guy) sync the throttle bodies without vacuum gages? Link to comment
Ken H. Posted May 23, 2007 Share Posted May 23, 2007 Can you, (well maybe you can, but can a regular guy) sync the throttle bodies without vacuum gages? Well you don't need vacuum gages, but you do need some way to measure the difference between the sides. Manometers, TwinMax, CarbStix are some ways. Link to comment
RFW Posted May 23, 2007 Share Posted May 23, 2007 what do you use for lubing the throttle cable? does it have to be replaced on a regular basis? Nothing. You are not supposed to lube it. It is teflon lined. Lubing will shorten its life. Link to comment
