David Vale Posted May 15, 2007 Share Posted May 15, 2007 As a novice mechanic with short stubby fingers, I struggle to replace the little rubber (?) cover for the timing hole. Easy enough to flick it out with a screwdriver or whatever - really hard to fit it back in. Is there a trick to it, or any suggestions for an easier-to-handle replacement? Thanks, David Vale Link to comment
ShovelStrokeEd Posted May 15, 2007 Share Posted May 15, 2007 Duct tape. Pick a color that matches. I think I have 3 of those in the bell housing of my R1100RS. Link to comment
NoHeat Posted May 15, 2007 Share Posted May 15, 2007 Mine was missing when I bought the used bike, so I replaced it with a cover that's intended for late-model airheads, on the recommendation of the OVAD valve adjustment instructions. Cost for the airhead plug was $1. It's a round plug, and the oilhead hole is oblong, but it works. Link to comment
Boffin Posted May 15, 2007 Share Posted May 15, 2007 As a novice mechanic with short stubby fingers, I struggle to replace the little rubber (?) cover for the timing hole. Easy enough to flick it out with a screwdriver or whatever - really hard to fit it back in. Is there a trick to it, or any suggestions for an easier-to-handle replacement? Thanks, David Vale Some people spear the plug with a screwdriver or bradawl to hold it whilst replacing. Do not worry if it pushes through - some bikes have four or five in there. I use aluminium foil tape. Duct tape would also work. Andy Link to comment
flyingreg Posted May 15, 2007 Share Posted May 15, 2007 I drilled a center hole and installed a 6-32 nylon screw that's about 1.5" long. I now have something to hold while pushing the bugger back into it's hole. Link to comment
Jim VonBaden Posted May 15, 2007 Share Posted May 15, 2007 Or simply ignore it altogether. You do not need to use the timing plug hole to do a valve adjust on an oilhed/hexhead. Simply use the arrows on the timing plug. When they are pointing out away from the bike check the rocker arms for loosness, and adjust the valves. Jim Link to comment
Effervescent Posted May 15, 2007 Share Posted May 15, 2007 A dab of spit as lube. -Eff Link to comment
breyfogle Posted May 15, 2007 Share Posted May 15, 2007 Simply use the arrows on the timing plug. When they are pointing out away from the bike check the rocker arms for loosness, and adjust the valves. "arrows on the timing plug" ?? Maybe "arrows on the cam chain sprockets" Link to comment
SageRider Posted May 15, 2007 Share Posted May 15, 2007 Grip the flange of the plug with a pair of needlenose pliers or a hemostat. Position plug then press in with finger. A little silicon lube on the plug helps. Link to comment
Jim Moore Posted May 15, 2007 Share Posted May 15, 2007 You can also put a hole in it, then put a 2" length of zip tie through it. Link to comment
David Vale Posted May 15, 2007 Author Share Posted May 15, 2007 Thanks for the advice all. Sounds like the duct tape I used after the last time I pushed one in could become the permanent solution. David Link to comment
Jim VonBaden Posted May 15, 2007 Share Posted May 15, 2007 Simply use the arrows on the timing plug. When they are pointing out away from the bike check the rocker arms for loosness, and adjust the valves. "arrows on the timing plug" ?? Maybe "arrows on the cam chain sprockets" LOL Typing in a hurry is a bad idea when you type as badly as I do. Yes, arrows on the timing chain gears in the heads: Jim Link to comment
strat Posted May 15, 2007 Share Posted May 15, 2007 I use a ratchet extension, make a small loop of duct tape and stick the plug on the end then hold it over the hole and use a screwdriver to press it on around the edges..works every time in short order. Cheers strat Link to comment
Bud Posted May 16, 2007 Share Posted May 16, 2007 Simply use the arrows on the timing plug. When they are pointing out away from the bike check the rocker arms for loosness, and adjust the valves. "arrows on the timing plug" ?? Maybe "arrows on the cam chain sprockets" LOL Typing in a hurry is a bad idea when you type as badly as I do. Yes, arrows on the timing chain gears in the heads: Jim +1 You don't have to remove tupperware or fool with that plug. Saves a lot of time and swearing. Link to comment
Steve_Witmer Posted May 16, 2007 Share Posted May 16, 2007 I selected a 3/8 inch socket slightly larger than the hole so that I wouldn't push the plug through. Using an extension, you can push fairly firmly to get the last bit of the plug seated. Link to comment
