Whip Posted May 12, 2007 Share Posted May 12, 2007 I'm getting a lot of ignition feedback/static from the autocom when I turn on the V1. Most of it stops when I turn off the V1. The volume and speed of the interference increases as the RPMs do..... The V1 in powered from an accessory wire(stock item) that is only powered when the key is on.(KTM950) The V1 and the Autocom are sharing the same ground. Help!!!!!!!!!!!!! We are leaving in the mornin for Torrey(The long way round) Whip Link to comment
Tasker Posted May 12, 2007 Share Posted May 12, 2007 Sounds like you may need to go back to the ADV... Link to comment
Limecreek Posted May 13, 2007 Share Posted May 13, 2007 I have a spare Autocom ground loop isolation cable. You can also find them at Radio Shack. I'll bring mine along with me just in case you come up empty. I can leave it out for you if you want to make a detour on your way out today. Link to comment
