johnciowa Posted May 11, 2007 Share Posted May 11, 2007 I felt it was time to replace my front pads. I was going to use EBC FA246 pads based on the good feeback around the net. However, my local stores cannot get any. Parts Unlimited had one pair and said they were discontinued after those were gone. Any suggestions on another aftermarket brake pad? I would like to try non-BMW if possible. Thanks, John Link to comment
Davis Posted May 11, 2007 Share Posted May 11, 2007 FA246 has been replaced by FA407 which now includes the spring clip. Parts Unlimited also distributes SBS pads which are good as well. Link to comment
Paul_Burkett Posted May 12, 2007 Share Posted May 12, 2007 You can check out these guys, I bought pads from them and they work like the OEM's. http://spieglerusa.com/ Link to comment
John Dickens Posted May 12, 2007 Share Posted May 12, 2007 I posted this change a while back. As Davis says the 246's have been replaced by an identical pad which also has the anti-squeal spring attached, the FA407 Link to comment
