grasslander Posted May 11, 2007 Share Posted May 11, 2007 Anybody here doing Jason's Heartland Topeka or Hallett Tulsa schools? I'll be at Heartland and kicking around going back to Hallett again. BTW R12St with Z6's at 32/32 for the track. Great grip! Link to comment
Green RT Posted May 13, 2007 Share Posted May 13, 2007 BTW R12St with Z6's at 32/32 for the track. Great grip! Can you really run Z6s with pressure that low? I run 39/42 on the street and I only weigh about 170 with ATGATT on. Maybe I am throwing away a lot of traction in favor of tire life. Link to comment
grasslander Posted May 13, 2007 Author Share Posted May 13, 2007 ST recommended pressure for "solo no luggage" is 32/36. On track you are running for 20-30min sessions and you need to heat up fast for traction. I want a high level of stick for the extended envelope I'm pushing on the track. I could probably go down a bit on the front and come up a bit on the rear. Depends on air temp and surface. I would never run 31/32 on road. If you ran this low on the road you will certainly kill tread life and maybe shouldn't be riding at the level that requires the additional traction! Link to comment
