jackhett Posted May 10, 2007 Share Posted May 10, 2007 Just changed the oil on my new 12RT for the first time. Saw the little metal gasket taped to the oil filter box. Couldn't find any place it would fit into the filter assembly Guess you know what I found in my drain oil. Goes on the drain plug, right? As you can tell, recently back to riding after a many year lay off. Things are different now, I guess. Thanks for your help. Link to comment
Rob Posted May 10, 2007 Share Posted May 10, 2007 Crush washer, use it on the drain plug. You're welcome, Link to comment
SageRider Posted May 10, 2007 Share Posted May 10, 2007 ...and welcome to the asylum... Link to comment
TEWKS Posted May 10, 2007 Share Posted May 10, 2007 It's never happened to me but, i've heard of the rubber gasket on the old oil filter sticking to the engine. So check that along with the crush washer on your next oil change. Pat Link to comment
jackhett Posted May 10, 2007 Author Share Posted May 10, 2007 At least I knew enough to check the rubber gasket on the filter. Thanks for your help. Leaving Saturday from the "tip of Michigan's thumb" to ride the whole Blue Ridge Parkway, then Gettysburg, PA, then home. Didn't want to leave a trail of oil. Link to comment
TEWKS Posted May 10, 2007 Share Posted May 10, 2007 . Didn't want to leave a trail of oil. Thats called GPS Harley style If your in Gettysburg, take a ride over to york PA. You can take a tour of the Harley factory there. It's well worth your time. Pat Link to comment
jackhett Posted May 11, 2007 Author Share Posted May 11, 2007 I know all about that. I'm riding with 4 guys on Harleys. Always the question: do I ride first to avoid the oil slicks or last to keep from being rear-ended if I have to stop fast? (That almost happened to me last fall being followed by one of the hogs.) Link to comment
Jim VonBaden Posted May 11, 2007 Share Posted May 11, 2007 ...and welcome to the asylum... Wrong forum! Jim PS FYYFF Link to comment
Whip Posted May 11, 2007 Share Posted May 11, 2007 WOW...WOW..WOW!!!! Port Hope Michigan. "The Little Town with the Big Welcome" Check your pm box.......the flashing thing next to [Logout] Cooooool! Whip Link to comment
Eureka Posted May 12, 2007 Share Posted May 12, 2007 Always ride first with Harley's. That way you won't go deaf from loud pipes saving lives. Link to comment
