Dog Posted April 12, 2007 Share Posted April 12, 2007 Has anyone replaced the straight wheel valve stems with 90* valve stems? If anyone has what diameter valve stem is the correct diameter, and where did you get them? Link to comment
bmwmick Posted April 12, 2007 Share Posted April 12, 2007 Has anyone replaced the straight wheel valve stems with 90* valve stems? If anyone has what diameter valve stem is the correct diameter, and where did you get them? Search on +valve +stem and you'll find LOTS of info. http://bmwsporttouring.com/ubbthreads/sh...true#Post831141 is just a sample. 0.453 is the hole size. Mick Link to comment
Dog Posted April 13, 2007 Author Share Posted April 13, 2007 Mick thanks, I did not want to remove my wheel and tire just to measure the vale stem hole. Link to comment
bmwmick Posted April 13, 2007 Share Posted April 13, 2007 Mick thanks, I did not want to remove my wheel and tire just to measure the vale stem hole. Just an FYI, those steel valve stems at PatchBoy.com for $0.99 are the same as the ones selling for $4 each at some of the suppliers. Mick Link to comment
