Lineareagle Posted April 6, 2007 Share Posted April 6, 2007 Did I read somewhere that you can use the front caliper bleed nipple to bleed the clutch system? i.e. remove nipple from caliper, remove grub screw, install nipple and bleed the clutch? Link to comment
BMWRich58 Posted April 7, 2007 Share Posted April 7, 2007 I used a bleed screw from an 1100 series. 1150 series won't work. REMEMBER when you screw in the bleed screw, that will open the circuit/fluid flow begins. Link to comment
