Swag Posted March 25, 2007 Share Posted March 25, 2007 Hi all, I'm getting read to do my 6k mile service been getting all the tools together that will be needed for the job. I think I've gotten everthing except for a spark plug wrench I've tried every deep socket I have in my tool box, none of them fit. Do I have to get the one from BMW, part# 123510, or is their something other then that, that will work? Thanks for the help. Link to comment
Roger_R Posted March 25, 2007 Share Posted March 25, 2007 http://www.lockitsocket.com/ Get one of these. Fits in the tunnel...you can use a torque wrench if you want..works perfect! Rog Link to comment
Swag Posted March 25, 2007 Author Share Posted March 25, 2007 http://www.lockitsocket.com/ Get one of these. Fits in the tunnel...you can use a torque wrench if you want..works perfect! Rog What size do I need? Link to comment
Mudman Posted March 26, 2007 Share Posted March 26, 2007 Bob, Two words Snap-On This socket fits due to a thin wall design reducing it's OD to clear the spark plug access. Socket grips the plug, all you need is an extension and drive/torque wrench. http://buy1.snapon.com/catalog/item.asp?...amp;dir=catalog Good Luck Link to comment
Jim VonBaden Posted March 27, 2007 Share Posted March 27, 2007 http://www.lockitsocket.com/ Get one of these. Fits in the tunnel...you can use a torque wrench if you want..works perfect! Rog What size do I need? 16mm. Jim Link to comment
JayW Posted March 27, 2007 Share Posted March 27, 2007 Why are you removing the plugs at 6k miles - you aren't going to replace them yet are you? Jay Link to comment
Jim VonBaden Posted March 27, 2007 Share Posted March 27, 2007 Why are you removing the plugs at 6k miles - you aren't going to replace them yet are you? Jay Makes it much easier to turn the engine for valve adjustments. Plus it never hurts to take a look at them. Jim Link to comment
loujack Posted March 28, 2007 Share Posted March 28, 2007 Thanks for the site. No shipping costs.... Now I'm 26 bucks poorer. Link to comment
Swag Posted March 28, 2007 Author Share Posted March 28, 2007 Why are you removing the plugs at 6k miles - you aren't going to replace them yet are you? Jay I have to find TDC to adjust the valve, in order to do that you have to take the Spark plugs out. Link to comment
Swag Posted March 28, 2007 Author Share Posted March 28, 2007 Bob, Two words Snap-On This socket fits due to a thin wall design reducing it's OD to clear the spark plug access. Socket grips the plug, all you need is an extension and drive/torque wrench. http://buy1.snapon.com/catalog/item.asp?...amp;dir=catalog Good Luck Thanks Mudman, $26 is better than the $62 A&S wants for the BMW wrench. I had a 5/8" plug socket turned down at work it seem to work okay. Link to comment
Mudman Posted March 29, 2007 Share Posted March 29, 2007 The no shipping charge is a nice touch, your welcome Link to comment
Mudman Posted March 29, 2007 Share Posted March 29, 2007 No doubt the turned down socket will work out fine. A good alternative Link to comment
