ratfink Posted March 22, 2007 Share Posted March 22, 2007 On my 99 R1100 RT-P the socket that is supposed to be for the horn relay is empty. My horn works fine though. I looked through the wiring schematics posted on BMWMC.net but can't find any clues. In looking at Tracy Priers web site where he discusses adding drivingng lights, I noticed his socket is empty also. (scroll down to the pic) http://www.myr1100rtp.netfirms.com/drivelight.htm I'm getting ready to add an airhorn and I thought I should look for the existing horn relay but it's gone or am I missing something (mentally) ??? Link to comment
GrumpyOldMan Posted March 23, 2007 Share Posted March 23, 2007 My 2000 RT-P (CHP configuration) had the complete Authority package installed (less radio) when I aquired it. The horn button operates the 'air' horn. The civilian horn is installed, but disconnected, and the horn relay bay is empty. The relay that operates my air horn is buried under the front tupperware on the right hand side. I suspect that this is the realy that is operating your horn. I have a picture that somewhat shows the relay location. My tupperware is currently installed or I would have taken a picture of the relay. See the attachment and look for the yellow pointer. The police horn relay is located behind the obstruction the pointer is pointing at. Hope this helps somewhat. Good luck. Link to comment
ratfink Posted March 23, 2007 Author Share Posted March 23, 2007 I think you are correct. They just hooked the civilian horn to the police relay when they stripped the police gear from the bike. The result is that I get power feeding back to the civilian relay terminal that would normaly go to the load and on one terminal that would power the coil. The other result is that the horn works even with the key off. I'll use the signal that feedsback from the horn to trigger the coil on my new horn relay. I can power the new horn from one of the fused police circuits under the radio box. This is all very handy cuz I am nounting the new horn where the carbon canister used to be or on the bracket for the radar gun "holster". Thanks again. Link to comment
rahbert Posted August 7, 2007 Share Posted August 7, 2007 Which socket is that? I didn't see any empty relay sockets on the picture you indicated. I am trying to determine why my horn stopped working after replacing the left combo switch on my ex-CHP R1100RTP. Link to comment
Davis Posted August 7, 2007 Share Posted August 7, 2007 The civilian horn relay is normally located in the empty slot two spaces over from the tan starter relay in the top row. Link to comment
