beemer_me_up Posted March 20, 2007 Share Posted March 20, 2007 I am doing more of my oun maintance and want to now try and adjust the valves myself. Looking for a good source of info on the subject. Thanks for any help you can provide. Link to comment
kioolt Posted March 20, 2007 Share Posted March 20, 2007 There's an excellent PDF file here. BMW Oilhead Tech Articles Link to comment
Jim VonBaden Posted March 21, 2007 Share Posted March 21, 2007 Check out my pictorial on the R1200 series. It is essentially the same, for the 1100/1150 series, including the specs. Click here to see it! Jim Link to comment
glwestcott Posted March 21, 2007 Share Posted March 21, 2007 Check out my pictorial on the R1200 series. It is essentially the same, for the 1100/1150 series, including the specs. Click here to see it! Jim Jim, that is the best pictorial I have seen on the subject. You da man! Link to comment
SoberBiker Posted March 21, 2007 Share Posted March 21, 2007 That was an excellent pictorial of the valve adjustment proceedure...Thanks! Link to comment
stubble! Posted March 21, 2007 Share Posted March 21, 2007 There's an excellent PDF file here. BMW Oilhead Tech Articles Specifically, this excellent file is essential for valves and most other maintenance tasks: http://www.ibmwr.org/r-tech/oilheads/R11Manual/Oilhead_Maintenance_2-25-02.pdf Jim: Great pictorial. Link to comment
flars Posted March 21, 2007 Share Posted March 21, 2007 One thing I would suggest: After removing the spark plug wire, but before removing the spark plug or the valve cover, use an air compressor to blow the dirt out of the hole around the spark plug. If you don't have a compressor, use a can of electrical contact cleaner or compressed air or somethin'. You won't believe how much crap accumulates in there in spite of the spark plug cover and spark plug wire. Link to comment
Jim VonBaden Posted March 22, 2007 Share Posted March 22, 2007 One thing I would suggest: After removing the spark plug wire, but before removing the spark plug or the valve cover, use an air compressor to blow the dirt out of the hole around the spark plug. If you don't have a compressor, use a can of electrical contact cleaner or compressed air or somethin'. You won't believe how much crap accumulates in there in spite of the spark plug cover and spark plug wire. Good advice, and thanks for the compliments. I have a video of the entire R1200 36K coming out in a few weeks that will be more detailed, and have every operation needed to do all services up to a 36K on the R1200, though 90% applicable to the R1100/R1150 series as well. Jim Link to comment
