ncsonderman Posted March 19, 2007 Share Posted March 19, 2007 Just wanted to get a sampling of ideas on how best to remove a plastic bag that melted to my exhaust. I think that it was one of the types that you get at the grocery that I managed to snag while riding to Florida last week. I applied a wet paper towel to the area for about 10 minutes with no positive results to speak of. Next idea: Metal Polish, Never Dull... Thanks for the thoughts! Link to comment
Tony_K Posted March 19, 2007 Share Posted March 19, 2007 No solvent will take it off. A straight edge razor and some scraping will. It wont scratch the stainless unless your really trying to. 3 or 4 zero steel wool to clean up afterwards. Link to comment
Ken H. Posted March 20, 2007 Share Posted March 20, 2007 Take the worst of it off hot. Carefully! Link to comment
ncsonderman Posted March 20, 2007 Author Share Posted March 20, 2007 Thanks guys. That's about what I expected. I could not believe the amount of litter as I rode South on I-77 through Charlotte. It turns out that a semi did not have a properly covered trailer hauling recyclables (spelling?) Tony, love the avatar I'm haven't messed with it enough to know how to get a moving image on there. Link to comment
IanW Posted March 20, 2007 Share Posted March 20, 2007 Oven cleaner will work, dont get it on anything else. Link to comment
s3steve Posted March 20, 2007 Share Posted March 20, 2007 Funny you should post this now. I had a green garbage bag touch the hot header pipe on my RT when I did the oil change for the winter layup and was going ask the same question today. What about a hot air gun and a scraper for the initial part and 0000 steel wool for the finish? Link to comment
ncsonderman Posted March 20, 2007 Author Share Posted March 20, 2007 Thanks Ian, I'll try it since I've already got it laying around the house. I can always fall back on the razor blades. Glad I could help Steve Link to comment
Tony_K Posted March 20, 2007 Share Posted March 20, 2007 If a hot air gun = heat gun then sure. But watch where you point the thing. Joe Oven cleaner = paint remover be very careful if you do this as the cleaner often times splats out. It can/ will mare the finish on painted surfaces, frame and some plastics . Not enough to peel paint but will dull the finish. Often times you wont see it in the garage but in the sun light... oops! Link to comment
Penrod Posted March 22, 2007 Share Posted March 22, 2007 Use laquer (sp?) thinner. Had the same thing happen to me, it came off with no, repeat no scratching. I polished afterwards with my favorite polish and all was like new. Link to comment
RickS Posted March 24, 2007 Share Posted March 24, 2007 Aluminum foil and WD-40. Cold exhaust, dirt and grime washed away, simply take a piece of aluminum foil and wad it up, spray WD-40 on the area to be cleaned and also on the foil. A little light rubbing and the plastic is gone. The theory is that the aluminum is softer than the chrome or stainless, the WD-40 lubricates and floats the debris away. I've used this method for years with excellent results. Link to comment
