SAMSAR Posted March 17, 2007 Share Posted March 17, 2007 I'm in the process of doing my first rear tire change on a 2002 1150RT. Conti Road Attacks. Getting the old front tire off the rim was much easier than getting the rear off. Any tips for getting the old tire off before I break out the grinder and cut it off? Using the Harbor Freight Tire Changing Station. Have a Wilco Bar too but the round plastic end is now snapped. Thoughts on what else might work? Thanks! Paul Link to comment
Spyder Posted March 17, 2007 Share Posted March 17, 2007 My first suggestion would be to lose the knuckleheads that are trying to help you and get someone who knows what they are doing Link to comment
SAMSAR Posted March 17, 2007 Author Share Posted March 17, 2007 What's that about names being changed to protect the innocent? Link to comment
Stan Walker Posted March 17, 2007 Share Posted March 17, 2007 Any tips for getting the old tire off before I break out the grinder and cut it off? Just be sure that the tire edge 180 degrees from where you insert the dismount bar is down in the deepest part (bottom) of the rim. Tires don't streach!!. Stan Link to comment
Yeeha! Stephen Posted March 17, 2007 Share Posted March 17, 2007 If you broke the tip off the bar, you were using it to pry the tire up over the wheel rim. That's a no-no. Don't use the bar like you would a lever or a tire iron. So hard to put into words, so watch these videos. Principle is the same for all machines. Go here and click "videos" from the menu. Then go watch videos # 10, 11, & 12 www.nomartirechanger.com Link to comment
smiller Posted March 17, 2007 Share Posted March 17, 2007 If you are breaking things or having to use a lot of physical effort when changing tires then stop... you are doing something wrong. Once you learn the proper technique you'll never have to force anything. Check out the videos and search the forum for tips. Also download Mitch's instructions for his Mojobar... they are very good, about as clear an explanation as you are going to find. After you do a few changes the light bulb will come on and it will be easy thereafter... don't give up... Link to comment
Jerry Johnston Posted March 17, 2007 Share Posted March 17, 2007 Like Stan said keep the tire bead in the center of the wheel when you start removing it - both sides. Link to comment
DouglasR Posted March 17, 2007 Share Posted March 17, 2007 I do all my own tire changing on my RT, K75, GS and dirt bikes all by myself with only rudimentary tools. Some time ago I posted Tire Change on Wire-Spoked GS Wheels , maybe that will offer some help. If you're forcing it, that's not right. Take care! Doug Link to comment
SAMSAR Posted March 18, 2007 Author Share Posted March 18, 2007 So hard to put into words, so watch these videos. Principle is the same for all machines. Go here and click "videos" from the menu. Then go watch videos # 10, 11, & 12 www.nomartirechanger.com Those videos were great and very helpful. I've downloaded a lot of the written instructions but, like you said, it helps to see it in action. Amazing how easy it can be when you know what you're doing. Will try it again in the morning... Thanks! Link to comment
DiggerJim Posted March 18, 2007 Share Posted March 18, 2007 My first suggestion would be to lose the knuckleheads that are trying to help you and get someone who knows what they are doing But they're the ones who know the magic of remounting Link to comment
DiggerJim Posted March 18, 2007 Share Posted March 18, 2007 If you are breaking things or having to use a lot of physical effort when changing tires then stop... you are doing something wrong. Once you learn the proper technique you'll never have to force anything. I expect that's why he's got the help he has -- they're hoping to make their mistakes on someone elses wheels so theirs are spanky new & pretty when they're done Link to comment
Dave C. Posted March 19, 2007 Share Posted March 19, 2007 If you broke the tip off the bar, you were using it to pry the tire up over the wheel rim. That's a no-no. Don't use the bar like you would a lever or a tire iron. So hard to put into words, so watch these videos. Principle is the same for all machines. Go here and click "videos" from the menu. Then go watch videos # 10, 11, & 12 www.nomartirechanger.com +1 for the no-mar tire bar and the tire lube. I have done several tire changes using the no-mar bar and it works just like the video. Be sure to get the Marc Parnes balancer as well ( no relation) jsut a great tool. Dave Link to comment
Jim VonBaden Posted March 21, 2007 Share Posted March 21, 2007 Check out my tire pictorial, that uses the HF unit. I have never had a hard time removing a tire with the stock HF bar. Jim Link to comment
JATO Posted March 21, 2007 Share Posted March 21, 2007 Lots of tire lube, both inside & outside of the seating surfaces makes it sooo much easier.---Jay Link to comment
