Couchrocket Posted March 16, 2007 Share Posted March 16, 2007 Any of you using Suburban's lowered shift lever in combination with their lowered rider pegs on an 1150RT? I'd be grateful for your comments, good or bad. TIA Link to comment
fatbob Posted March 16, 2007 Share Posted March 16, 2007 Scott: I am, I like it a lot. I could'nt shift my RT after I put on the peg droppers without this lever. It's kind of a bugger to install, but well worth the effort. Bob Link to comment
HI-TECH-CHECK Posted March 16, 2007 Share Posted March 16, 2007 I also have both of them on my 97. Well worth it for the comfort. Link to comment
g_nuse Posted March 16, 2007 Share Posted March 16, 2007 Scott: I am, I like it a lot. I could'nt shift my RT after I put on the peg droppers without this lever. It's kind of a bugger to install, but well worth the effort. Bob Will you fill us in on the difficulty of the shifter installation? Thanks. Link to comment
Couchrocket Posted March 17, 2007 Author Share Posted March 17, 2007 Will you fill us in on the difficulty of the shifter installation? Thanks. Ditto, thanks! Link to comment
Redbrick Posted March 17, 2007 Share Posted March 17, 2007 Kathy46 has one on her 1150RT with lowered Suburban pegs and she likes it...Had it installed (wimp-like) and had the adjuster screwed all the way up on the stock lever to try and make it work with lowered pegs by lowering the toe...It didn't and then changed to the Suburban shifter without re-adjusting the rod....It let the shifter go too far down and hit the bottom of the slot in the side panel and it would jump out of first 'cause it wasn't completely in gear....Readjustment worked and it's fine.....Well made products and expensive.... Phil........Redbrick Link to comment
Tank Posted March 17, 2007 Share Posted March 17, 2007 Not really hard at all .....take your time and all will be worth it. Link to comment
Tank Posted March 17, 2007 Share Posted March 17, 2007 BTW, all linkage will go back together just like it was disassembled., the lever is just reconfigured. Link to comment
Couchrocket Posted March 17, 2007 Author Share Posted March 17, 2007 Not really hard at all .....take your time and all will be worth it. BTW, all linkage will go back together just like it was disassembled., the lever is just reconfigured Thanks! I'll order them up on Monday! Link to comment
fatbob Posted March 18, 2007 Share Posted March 18, 2007 Scott: You need to remove the left fairing and the left peg / shifter mounting plate. It is best to get the adjustment right (rod with adjustable length) before you re-install the plate. It's tough to adjust it with the plate in place. You'll enjoy the shifter, it makes the low pegs work perfectly. Bob Link to comment
Tank Posted March 18, 2007 Share Posted March 18, 2007 Scott: You need to remove the left fairing and the left peg / shifter mounting plate. It is best to get the adjustment right (rod with adjustable length) before you re-install the plate. It's tough to adjust it with the plate in place. You'll enjoy the shifter, it makes the low pegs work perfectly. Bob thanks Bob Scott... I must have been just lucky when i installed my shifter lever as I didn't adjust anything and it has been a good fit for my foot (size 91/2 Oxtar riding boot) Link to comment
Couchrocket Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks for this info... very helpful. Link to comment
