davewave Posted March 15, 2007 Share Posted March 15, 2007 I recently purchased a 2004 R1150RT, it seems that the parking lamp (little bulb near lens) is always on. Is this normal? Link to comment
Green RT Posted March 15, 2007 Share Posted March 15, 2007 Maybe you are turning the key too far when you turn it off. If you go past "Off" you get to a "Parking-Lamp-On" position. At least this is so on the 1100RT. I assume the 1150 is the same. Link to comment
Slyder_Steve Posted March 15, 2007 Share Posted March 15, 2007 Yep, same on the 1150. The "P" is one click too far--unless, of course, you're wanting your parking lamp lit And welcome to the board!! Steve Link to comment
ratfink Posted March 15, 2007 Share Posted March 15, 2007 I recently purchased a 2004 R1150RT, it seems that the parking lamp (little bulb near lens) is always on. Is this normal? In addition to being on when the key is in the fully counterclockwise position it will be on whenever the headlight is on. It is hard to see this because the headlight pretty much drowns it out. I have always assumed that that this is in case your headlight bulb burns out you will still be visible to others in the dark. If it is on any other time you may have a problem. Link to comment
DavidEBSmith Posted March 15, 2007 Share Posted March 15, 2007 I have always assumed that that this is in case your headlight bulb burns out you will still be visible to others in the dark. Not entirely. It's actually called the "front position lamp" or "parking lamp" and is used in Europe when parking on narrow streets, so make your vehicle visible. It also incidentally provides some minimum visibility if your headlight burns out. Link to comment
AndyS Posted March 15, 2007 Share Posted March 15, 2007 When ignition is on the side light (- position light - parking light ) is always on (certainly on my 2004 spec. Andy Link to comment
davewave Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks for answering me. What a great bike the R1150RT is. Link to comment
