Replacing my rear brake rotor
milesandmiles
milesandmiles
2000 R1100RT-P Any pointers? Is that little hubcap a pry off or a bayonet mount? Is this a straight forward procedure or does the ABS require any special consideration? I walked up to it with my tools, took one look at my new baby, and came right back in the house to log into bmwsporttouring. I'm not doing this alone. lurker.gif Thanks Brad
By "little hubcap" are you referring to the left side center cap that covers the lug bolts? It just pops off with a screwdriver or similar.
The rotor replacement is straight forward. The only 'gotcha' to be aware of is the Loctite on the rotor to wheel bolts. A little heat will do ya.
No ABS considerations/issues, the sensor can stay where it is.
If you don't have the re-assembly torques specs, post back and someone will get them for you.
