MarkEngland Posted March 11, 2007 Share Posted March 11, 2007 Where is a good place to "pull power" for my Blue Sea fuse box that works with the bike key: Off when the bike is Off On when turned to ACC On when the bike is On On my LT, there was a BMW part that pluged into the back of a Aux Power plug (Powerlet) in a "Y" fashion that worked well. A little hard to install, but did not involve cutting into factory wiring. Any suggestions would be great. Thanks Mark Link to comment
John Bentall Posted March 11, 2007 Share Posted March 11, 2007 There is an optional "Y" cable to add an extra power socket on the rear of the R1200RT, that might be similar to what you had on the LT. I chopped the end off this cable and wired it direct to the battery so that I have a non-CANBUS outlet for my battery charger. Link to comment
MarkEngland Posted March 11, 2007 Author Share Posted March 11, 2007 There is an optional "Y" cable to add an extra power socket on the rear of the R1200RT, that might be similar to what you had on the LT. I chopped the end off this cable and wired it direct to the battery so that I have a non-CANBUS outlet for my battery charger. The bike came with an extra power outlet for the passenger on the back left - I bet that is what the dealer/factory used. I wonder if I can "Y" off it for a second time? Link to comment
skyking44 Posted March 11, 2007 Share Posted March 11, 2007 I purchased the "Add Plug Socket Lead" BMW part #61132316621 to tap into my RT's Aux Plug. Link to comment
Albert Posted March 12, 2007 Share Posted March 12, 2007 Mark, I tapped off the auxilliary socket (left rear) and it works fine. The tap is sent to a relay I used to power a Centech fuse panel. The relay stays hot for approximately 60 seconds after the key is turned off (as do the aux plugs). Link to comment
MarkEngland Posted March 12, 2007 Author Share Posted March 12, 2007 Mark, I tapped off the auxilliary socket (left rear) and it works fine. The tap is sent to a relay I used to power a Centech fuse panel. The relay stays hot for approximately 60 seconds after the key is turned off (as do the aux plugs). Yep, thats what I ended up doing. Since I ride solo, that rear plug will never be used anyway. I like the fact it stays on after the key is turned off. I would rather have used the BMW "Y" plug, but...... well we all know how it goes when the bike is already tore apart. Thanks Mark Link to comment
