90RedRider Posted March 10, 2007 Share Posted March 10, 2007 Does anyone have a source for a mount for a CB antenna on the RT. Thank you for any help. Sid Link to comment
flyingreg Posted March 10, 2007 Share Posted March 10, 2007 Does anyone have a source for a mount for a CB antenna on the RT. Thank you for any help. Sid Have you considered just making one for your RT. It would be quite simple actually, for any model of RT. Just a thought. And the personal satisfaction is priceless. Link to comment
Heck Posted March 11, 2007 Share Posted March 11, 2007 Does anyone have a source for a mount for a CB antenna on the RT. Thank you for any help. Sid Check with "Tool Man" on this board.... Link to comment
twilmotte Posted March 11, 2007 Share Posted March 11, 2007 Sid, I have one of Toolman's CB antenna mounts. PM me if you'd like to see what it looks like on my RT. Tom Link to comment
GordonZ Posted March 12, 2007 Share Posted March 12, 2007 I recently installed a Firestik DS14FG model zero ground plain CB antenna on my R1200RT and it works great. I didn't use a bracket but instead drilled a small hole in the fairing on the right side just outside the windshield's range of travel. It is mounted in the exact location the factory FM antenna is located, so that wouldn't work for someone with an antenna already located there. But if you don't mind the location in front and to the right side, the Firstik works great. I bought mine at Clay's Radiio Shop (I believe the web address is http://www.claysradioshop.com/citizensband_firestick_ds14fg.htm for $45.00. It works great with te J&M CB. Link to comment
