waverider Posted March 9, 2007 Share Posted March 9, 2007 I change windscreens from time to time depending on my mood and the temp outside (between CB, Z-tek & stock). Anyway, it seems I put a little too much a$$ behind a couple screws and stripped the hole itself out. I tried re-tapping (cutting) the hole to no avail. I can purchase the support arms it seems for about $90 a piece (nice). Anyone done this and have a different work around? It's just one screw on each each side, the other four are fine. Link to comment
SteveHebert Posted March 9, 2007 Share Posted March 9, 2007 Larry, I am sure that you can re-tap and insert a helicoil. Dudley mat have what you need. Link to comment
IanW Posted March 9, 2007 Share Posted March 9, 2007 Drill to lager size, tap new thread and fit with larter screws (only in the damaged holes) you have nothing to lose. Ian Link to comment
Tony_K Posted March 9, 2007 Share Posted March 9, 2007 Drill to lager size, tap new thread and fit with larger screws (only in the damaged holes) Ian is correct. There is not enough meat there for a heli. Remember it's metric! Link to comment
New1200RTRider Posted March 9, 2007 Share Posted March 9, 2007 You Can Try Loctite form a thread kit Link to comment
