cali_beemer Posted March 8, 2007 Share Posted March 8, 2007 My understadning is that the throttle bodies can be synched with using a manometer. I plan on giving this a try and figured that I should invest in a manometer to have on hand for this. Does anyone know whats a good unit to buy thats friendly with a 97 oilhead? A good place to buy online? Are there any other tools needed I should know about? My neighbor is pretty familiar with this procedure to give me hand. Any tips or advice? Link to comment
philbytx Posted March 8, 2007 Share Posted March 8, 2007 I use a Morgan Carbtune on mine. Nice product, easy to use.... Link to comment
Ken H. Posted March 9, 2007 Share Posted March 9, 2007 There are lot of options available. The mentioned CarbTune, the TwinMax electronic unit, many people make there own water manometer, others too. Use the search feature of this web site for these terms and you will find several threads about each one. Link to comment
cali_beemer Posted March 9, 2007 Author Share Posted March 9, 2007 I have seen some people love or hate the twin-max. Is there really a benefit to either the twin-max or the morgan carbtune? Is one easier to use? give better results? accurate readable display? The carbtune disply looks small and hard to read but thats just going off the picture on there website. Link to comment
Ken H. Posted March 9, 2007 Share Posted March 9, 2007 Personal opinion, I don't find the TwinMax sensitive enough. I can see finer errors with a water manometer. Others will say the TwinMax is 'good enough.' It does offer the one advantage that you can go ride the bike with it attached and observe sync under load. Link to comment
Charles Elms Posted March 9, 2007 Share Posted March 9, 2007 Make your own water manometer for about $5. If you don't like it then go search for a commercial unit. I'm quite happy with the $5 solution. Do a search for the materials and instructions. Link to comment
Green RT Posted March 9, 2007 Share Posted March 9, 2007 Make your own water manometer for about $5. If you don't like it then go search for a commercial unit. I'm quite happy with the $5 solution. Do a search for the materials and instructions. Ditto. I started with 3/16" ID tubing, but found that it was hard to get air bubbles out when they occurred. So I switched to 3/8" ID tubing with a short piece of the 3/16" on each end to fit on the throttle bodies and to act as restricters. Works great now. Link to comment
cali_beemer Posted March 10, 2007 Author Share Posted March 10, 2007 I know that I could make one but I think I will purchase one. Are there any other choices out there besides the twin max and the carbtune? Will the twin max be just as accurate as the carbtune? Link to comment
Ruddy Posted March 10, 2007 Share Posted March 10, 2007 Here's an article about making your own $1.55 Carb Sync Tool. Link to comment
Lineareagle Posted March 10, 2007 Share Posted March 10, 2007 Here is a site for the commercial u-tube manometer. Dwyer Manometers Link to comment
