Mike05 Posted March 8, 2007 Share Posted March 8, 2007 While changing tires this weekend we noticed uneven wear on the rear brake pads; the "inside" pad was half as thick as the other. Is this normal or something to be concerned about?? Any thoughts? Link to comment
Ken H. Posted March 8, 2007 Share Posted March 8, 2007 I've seen it a couple of times, but I'm not really convinced it's "normal." Typically it is symptomatic of the caliper not correctly sliding on its pins. OTHO I really couldn't find a real cause of it, so I just put new pads on the two bikes that were showing that wear pattern and went on. Link to comment
Jim VonBaden Posted March 8, 2007 Share Posted March 8, 2007 While changing tires this weekend we noticed uneven wear on the rear brake pads; the "inside" pad was half as thick as the other. Is this normal or something to be concerned about?? Any thoughts? Might be a good idea to pull the caliper, remove the pads and clean and lube the shaft they mount to. It is possible that the pads are binding. Jim Link to comment
DonB Posted March 8, 2007 Share Posted March 8, 2007 Going back to my 95 GS, 97RT, 02RS all have worn inside pad quicker. Link to comment
RFW Posted March 9, 2007 Share Posted March 9, 2007 The hydraulic pressure on both pads is by definition, equal. Since the pistons are the same diameter, that means the force on each piston is identical. Thus, there are only a few possible explanations for the problem... 1. You hae a sticking piston. 2. One side of your disk is rougher than the other (possibly due to an earlier pad wearing through to the metal?). 3. Somehow, more dirt is being thrown up on one side of the disk, than the other (not very likely). 4. The two pads are somehow different in composition. So, check to see if the pistons push back into their calipers with equal ease. Check both sides of your disk for equal surface roughness. If all that is OK, then replace the pads and check later to see if the problem persists. Link to comment
FrankBrown Posted March 9, 2007 Share Posted March 9, 2007 It's normal. There is equal pressure on both pistons, however, both pistons are on the same side. Link to comment
