kopov260 Posted February 26, 2007 Share Posted February 26, 2007 I was wondering if there is any way to check condition of the clutch. For example half worn, not worn at all or almost gone. I know it all depends on the rider. My bike has more than 22K now and I am trying not to ride/slip the clutch but just wanted to check anyway. Thanks. Link to comment
JayW Posted February 27, 2007 Share Posted February 27, 2007 Other than disassembling the housing and taking a look, I don't think there is any way to check it before actual slippage occurs at the end of its life. However, provided you are not overly aggressive with your clutching technique, I would be surprised if yours is even close to half worn. Jay Link to comment
tom collins Posted February 27, 2007 Share Posted February 27, 2007 if you are not overaggressive, it should go for 70,000 or more. tom collins Link to comment
LuckyLeif Posted February 27, 2007 Share Posted February 27, 2007 Doesn't the fluid level in the reservoir rise as the clutch plate wears down? Link to comment
kopov260 Posted February 27, 2007 Author Share Posted February 27, 2007 I've heard that and it looks that it's full and I can't see the upper level. Link to comment
LuckyLeif Posted February 27, 2007 Share Posted February 27, 2007 I've heard that and it looks that it's full and I can't see the upper level. I recall that some of the early 12GS (not sure about 12RT) had clutch problems associated with leaking seals. You probably are still in waranty period, so good idea to have it checked out. You might get a fresh clutch if you have the seal issue. Link to comment
KDeline Posted February 28, 2007 Share Posted February 28, 2007 if you are not overaggressive, it should go for 70,000 or more. tom collins Bah, I have 128,000 still going strong. Link to comment
kopov260 Posted February 28, 2007 Author Share Posted February 28, 2007 Is it on the bike shown in your avatar? What bike is it? Link to comment
dnyman Posted February 28, 2007 Share Posted February 28, 2007 I was wondering if there is any way to check condition of the clutch. For example half worn, not worn at all or almost gone. I know it all depends on the rider. My bike has more than 22K now and I am trying not to ride/slip the clutch but just wanted to check anyway. Thanks. You'll soon know when your clutch is on the way out, trust me. Slipping clutches are pretty easy to spot. And it'll most likely start happening all of a sudden, rather than over a period of time. At least that's been my experience with dry clutches. Dave. Link to comment
