E30TECH Posted February 25, 2007 Share Posted February 25, 2007 When I bought my RT, I traded the seller my Battery Tender Plus for his BMW Gel Battery charger. Is there any real difference between the 2 chargers? Link to comment
GordonB Posted February 25, 2007 Share Posted February 25, 2007 Depends on the BMW charger model you have. If the metal case is similar to the Battery tender, then there's not much dif. if any. Both made by the same company. Link to comment
E30TECH Posted February 25, 2007 Author Share Posted February 25, 2007 Depends on the BMW charger model you have. If the metal case is similar to the Battery tender, then there's not much dif. if any. Both made by the same company. They look the same, only the label is different. So this charger would work on an Odyssey battery? Link to comment
GordonB Posted February 26, 2007 Share Posted February 26, 2007 The latest version of BMW's charger will work on Std lead Acid, Gel, And AGM (Odessey). Key word is latest version. Go to BMW's site, look up gear, then maintenance, select charger, see if they look the same. FWIW....It should read "Advanced battery Charging System" on the front. Link to comment
E30TECH Posted February 26, 2007 Author Share Posted February 26, 2007 The latest version of BMW's charger will work on Std lead Acid, Gel, And AGM (Odessey). Key word is latest version. Go to BMW's site, look up gear, then maintenance, select charger, see if they look the same. FWIW....It should read "Advanced battery Charging System" on the front. Thanks Link to comment
ShovelStrokeEd Posted February 26, 2007 Share Posted February 26, 2007 When all is said and done, it shouldn't matter a whit what charger you use. The one exception would be if the battery has been allowed to discharge some large percentage of its capacity. After all, the charging system on the bikes remains the same and seems to keep the bike charged pretty well. I suppose there is some difference in the mode required for a maintenance charge but, I never do that seeing that I live in a warm climate and can ride my bike(s) year round. Link to comment
E30TECH Posted February 26, 2007 Author Share Posted February 26, 2007 After all, the charging system on the bikes remains the same and seems to keep the bike charged pretty well. I guess I never thought of that. Its the simple things some of us tend to overlook Since the previous owner kept his Harley, I told him that it was sacrilegious to charge a Harley with a BMW charger. The same thinking also got him to fork over the BMW bike cover as he wanted to keep it for the Harley. Link to comment
