Djonmoss49 Posted February 24, 2007 Share Posted February 24, 2007 Have any of you found a convenient place to mount this fuse panel on an Rt. I have an 03' R1150Rt. I have looked around under the seat but have not found quite enough room. Ideas?? Dave Link to comment
AndyT Posted February 25, 2007 Share Posted February 25, 2007 I mounted my Centech on the plastic top of the fuse box under the seat. I used the self tapping screws right into the plastic lid (use a size that doesn't go in too far and hit a fuse)! I then ran heavy guage wire to the battery terminals to power the Centech and started hooking up my farkles. I am sure others have better places to mount it and I've seen some clever set ups in threads here, but this worked for me! Link to comment
Kroref Posted February 25, 2007 Share Posted February 25, 2007 I mounted mine under the seat on the backside of the tail light assy via a 2"X 2" piece of industrial velcro. It's back out of the way and yet accessible when you need to bring it out to add a circuit. Link to comment
flyingreg Posted February 25, 2007 Share Posted February 25, 2007 I mounted one in the tankbag, and another on top of the air cleaner lid. It is held in place with a couple dabs of silicone, making removal easy for checking filter now and then. Are you planning to use a switched relay to power the fuse panel? It is a good idea to do so. Centech sells a couple of really good waterproof relays. BTW, welcome to the DB. Link to comment
Eckhard Grohe Posted February 25, 2007 Share Posted February 25, 2007 Give a look at the Eastern Beaver website. He sells some pre assembled wiring looms for various applications including the Centech panels. Link to comment
Weyman Posted February 26, 2007 Share Posted February 26, 2007 I'll second the recommendation of Eastern Beaver. I bought the kit with the relay; EB attached the Centech terminal connectors to the relay wiring before shipping. All I had to do was connect to battery, then attach the relay trigger wire to an existing switched circuit (Eastern Beaver even included Posi-Tap connectors for that part). I mounted the fuse box under the rear seat of my LT, on the very edge next to the saddlebag. It didn't work when I first hooked it up; then I figured out that the inline fuse holder on the battery harness did not have a fuse already installed. EB provided two fuses; I thought they were both spares! Felt pretty stupid poking everything with a circuit tester just to find that I hadn't put in a fuse. Link to comment
