bullet Posted February 23, 2007 Share Posted February 23, 2007 Let's hope that this is a non-issue: I have removed the exhaust pipes from my '02 1150RT for the purpose of ceramic coating and have removed the oxygen sensor which at this point is just hanging there. While doing some other routine cleaning I turned the key and did not hear the fuel pump doing its self-check. Does anyone know if it is the Motronic that is sensing the disconnect of the oxygen sensor and therefore not allowing the fuel pump to operate? I am quite certain that all connections to the fuel tank are in good order and the fuses also appear to be good (oddly enough, the 2 spares have blown - go figure). I would very much appreciate any input from anyone who is familiar with the electronics of the RT and thank them in advance for their response. Link to comment
E30TECH Posted February 23, 2007 Share Posted February 23, 2007 I dont think the motronic is that smart. Do you have the kill switch on the off position? Maybe it is in gear with the side stand down? Link to comment
bullet Posted February 24, 2007 Author Share Posted February 24, 2007 E30Tech: Thanks for the reply. It seems the side stand is just a tad smarter than I am. That's what happens when the bike is in the garage for 3 months. The machine is looking smart. I, obviously, am not. Link to comment
Steve W. Posted February 24, 2007 Share Posted February 24, 2007 On my '01 GS the O2 sensor has been unplugged for about 10000 miles. The fuel pump works just fine, LOL. I have a Remus full system with no cat. Check the large plug for the tank wiring. Do you have the RID level display? Cheers Steve Link to comment
E30TECH Posted February 24, 2007 Share Posted February 24, 2007 E30Tech: Thanks for the reply. It seems the side stand is just a tad smarter than I am. That's what happens when the bike is in the garage for 3 months. The machine is looking smart. I, obviously, am not. Glad to hear it was an easy 'fix' Link to comment
David_Charlton Posted February 24, 2007 Share Posted February 24, 2007 Hi Bullet,I had my pipes ceramic coated also but nobody told me that once the temp' exceeds 700 degrees or so, the aluminium melts and turns a dark grey, so when you try to get everything equal, holding it a 4000rpm, make sure you have lots of fans cooling the pipes, David Link to comment
bullet Posted February 24, 2007 Author Share Posted February 24, 2007 So it's just a discoloration, not a complete "meltdown" (breakdown?) of the coating? And this discoloration appeared where - only in the area of the exhaust ports or the entire header? Curious if I wasted my money or not. How is the catalytic converter/muffler? -Bullet. Link to comment
David_Charlton Posted February 25, 2007 Share Posted February 25, 2007 It was a melt down, the shine was replaced by a grey colour, which virtually matched the colour of my RT,titanium grey. The discolouration crept to where the first bend in the pipes from the cylinder heads are,the rest of the area was fine, David Link to comment
E30TECH Posted February 25, 2007 Share Posted February 25, 2007 1bmwfan did his and did not have any problems. Could it be the quality of work? www.performancecoatings.com 1bmwfan's pictures of his exhaust Link to comment
David_Charlton Posted February 25, 2007 Share Posted February 25, 2007 Nice job, I had mine finished in a polished style aluminium not satin but as already stated, when time comes for a tune up,just make sure they don't get too hot ! Link to comment
