TowerMonkey Posted February 21, 2007 Share Posted February 21, 2007 Did I miss something? How can I bring up the Lat/Log of a saved location? I did see the Lat/Log displayed when I saved the location and gave it a name. I have version 3.0 installed. Link to comment
Chuck Hatcher Posted February 21, 2007 Share Posted February 21, 2007 Did I miss something? How can I bring up the Lat/Log of a saved location? I did see the Lat/Log displayed when I saved the location and gave it a name. I have version 3.0 installed. That's so incredibly simple you will be embarrassed to have asked. All you have to do is ride to the the saved location and touch the icon again. No problem. Link to comment
TowerMonkey Posted February 21, 2007 Author Share Posted February 21, 2007 WOW! I can't believe I missed that one. It's always the simple things that bite you in the as$. Link to comment
tobyzusa Posted February 21, 2007 Share Posted February 21, 2007 Did I miss something? How can I bring up the Lat/Log of a saved location? I did see the Lat/Log displayed when I saved the location and gave it a name. I have version 3.0 installed. I have a solution, but it isn't elegant. Import the file into Mapsource, select the location you want and add a waypoint. The waypoint will have the lat/long, similar to this: N29 56.914 W99 28.600. My guess is you wanted to do this on the Zumo alone, right? If so, I don't know how. Link to comment
hopz Posted February 21, 2007 Share Posted February 21, 2007 Did I miss something? How can I bring up the Lat/Log of a saved location? I did see the Lat/Log displayed when I saved the location and gave it a name. I have version 3.0 installed. Jerry... you might also want to check this out for other Zumo information: http://razorbiker.com/zumo/index.php Link to comment
James Clark Posted February 21, 2007 Share Posted February 21, 2007 Did I miss something? How can I bring up the Lat/Log of a saved location? I did see the Lat/Log displayed when I saved the location and gave it a name. I have version 3.0 installed. From startup screen: Setup>System>GPS Mode>Off BACK to startup screen Where To>Favorites>(select)>Map>Set Loc BACK to startup screen View Map>touch navigation icon Link to comment
Chuck Hatcher Posted February 21, 2007 Share Posted February 21, 2007 From startup screen: Setup>System>GPS Mode>Off BACK to startup screen Where To>Favorites>(select)>Map>Set Loc BACK to startup screen View Map>touch navigation icon Brilliant! I mean, not exactly convenient, but it works, and you have to admire the effort it took to figure it out. Link to comment
TowerMonkey Posted February 23, 2007 Author Share Posted February 23, 2007 Great site for Zumo stuff. Thanks Link to comment
TowerMonkey Posted February 23, 2007 Author Share Posted February 23, 2007 Jim, I will have to try this. Not exactly the one button solution I was expecting. It should be as simple as view all way point info. Was this in the manual? Thanks Link to comment
James Clark Posted February 23, 2007 Share Posted February 23, 2007 Jim, I will have to try this. Not exactly the one button solution I was expecting. It should be as simple as view all way point info. Was this in the manual? Thanks Manual? The "set location" with "GPS off" has been around for a while. The Lat/Lon/Elev display on the "save this location" prompt is new for V3. Link to comment
