GordonB Posted February 17, 2007 Share Posted February 17, 2007 Pulling the number 5 fuse, how long? Instant? or is there residual power? Link to comment
John Dickens Posted February 17, 2007 Share Posted February 17, 2007 Opinions are divided. Some say 15 seconds. Others say pull the fuse, go have a beer, put the fuse back in. Link to comment
ShovelStrokeEd Posted February 17, 2007 Share Posted February 17, 2007 Aren't those the same time period?? Since there is no backup battery inside the ECU, duration of the fuse pull is unimportant. Pull it out, stick it back in, the ECU will reset. Link to comment
1fastjunebug Posted February 23, 2007 Share Posted February 23, 2007 Pulling the number 5 fuse, how long? Instant? or is there residual power? There are others on this forum who are much more qualified than me, but I don't think this reset procedure applies to the 1100 cc engines, only the 1150's. Please correct me if I am wrong. Link to comment
Ken H. Posted February 23, 2007 Share Posted February 23, 2007 Pulling the number 5 fuse, how long? Instant? or is there residual power? There are others on this forum who are much more qualified than me, but I don't think this reset procedure applies to the 1100 cc engines, only the 1150's. Please correct me if I am wrong. Pulling the fuse will reset the Motronic on either series. It's what you do next that differs. On the R1150xx series you do the throttle reset procedure next, on the R1100xx series you do not. Link to comment
chipsonfriday Posted February 24, 2007 Share Posted February 24, 2007 Excuse my ignorance - but why would we perform a Motronic reset in the first place? Link to comment
GordonB Posted February 24, 2007 Author Share Posted February 24, 2007 To clear the fault codes. In my case I was experiencing ABS faults which I later learned are stored in the ABS unit, not the Motronic. And to add, I learned the ABS unit is capable of storing only one fault at a time. Link to comment
