ElevenFifty Posted February 15, 2007 Share Posted February 15, 2007 FRS? CB? Autocom or Starcom or whatever the com system is . . . what RADIO do you use and recommend? Link to comment
AZKomet Posted February 15, 2007 Share Posted February 15, 2007 The Kenwood military grade is what I use. I do believe it is the 3100? I would steer you away from this for 1 reason. To get to the privacy channels it is complicated and a PIA! There are other Kenwoods that have a digital readout that is much simpler to use. The 3100 has no dig readout. It is sturdy and weatherproof but that is where it stops. Check out the Kenwood site for all your options. Link to comment
Mr_Ed Posted February 15, 2007 Share Posted February 15, 2007 Dependa on who you want to talk to. Overwhelmingly folks on this board use FRS or GMRS radios. Personally I use an ICOM GMRS radio. It has the ability to work on the FRS channels and is able to transmit at a higher wattage than standard FRS units. Oh.... and go with an Autocom.... top rate units. Link to comment
mikeR1100R Posted February 15, 2007 Share Posted February 15, 2007 My wife and I use an Autocomm system with Kenwood TK 3101 GMRS radios. The system works very well for us. Do not cheap out on the radio. You will not be satisfied and will wind up paying out the money for the good ones anyway. (We learned our lesson the hard way). Good luck. Mike. Link to comment
E30TECH Posted February 15, 2007 Share Posted February 15, 2007 My wife and I use an Autocomm system with Kenwood TK 3101 GMRS radios. The system works very well for us. Do not cheap out on the radio. You will not be satisfied and will wind up paying out the money for the good ones anyway. (We learned our lesson the hard way). Good luck. Mike. I have the same. The Kenwood TK3101 can be found on Ebay for reasonable prices. New they are @ $200. Autocom sells the bike powered interface for @ $80. Link to comment
waverider Posted February 16, 2007 Share Posted February 16, 2007 I have Baehr, top shelf stuff... you get what you pay for. Never had a problem, never heard of any. Link to comment
Shaman97 Posted February 16, 2007 Share Posted February 16, 2007 Are there radios out there that will not work with the Autocoms/Starcoms? If I get a unit that has the remote input/headphone outputs, should they all be at least functional? If not, what are the 'bare-bones' requirements of the handheld radios to work with the different interfaces out there? Link to comment
johnlt Posted February 16, 2007 Share Posted February 16, 2007 One advantage of going the Kenwood route is the "bike powered" interface with autocom. You don't have to mess with batteries. Quality is great. The only disadvantage of autocom is that it is problematic with CB radios. I use both. CBs when alone on the interstates. I got it to work ok but had to screw around with cable routing etc. to get clear signals. Link to comment
Aluminum_Butt Posted February 16, 2007 Share Posted February 16, 2007 Are there radios out there that will not work with the Autocoms/Starcoms? There is a pervasive rumor that the Midland GXT series does not play well with Autocom. Link to comment
Bill_Walker Posted February 16, 2007 Share Posted February 16, 2007 The Kenwood military grade is what I use. I do believe it is the 3100? I would steer you away from this for 1 reason. To get to the privacy channels it is complicated and a PIA! There are other Kenwoods that have a digital readout that is much simpler to use. The 3100 has no dig readout. It is sturdy and weatherproof but that is where it stops. Check out the Kenwood site for all your options. I use the Kenwood TK-3131 (aka Freetalk XLS, vs the 3101 Freetalk XL). It has a display, which makes channel changing much easier. Unfortunately, Autocom only has a bike-powered lead for the Freetalk XL, so I have to use batteries. I've found the provided NiCads are good for a day, but I do have to lug the charger. On the other hand, it can also use standard AA batteries, available everywhere. Link to comment
Hawk28 Posted February 16, 2007 Share Posted February 16, 2007 I just went through this and, boy, did I feel like a rookie. I went with Baehr for comm and Midland GMRS radios. A buddy of mine said to check with the communicator co. (Baehr, Autocomm, J&M , etc, etc.) first as some comm units seem to work better with certain brand radios. This is no slam on any radios or comm units, just some are more suited to each other. We have now reached the end of my expertise in this area. Link to comment
