Heyfrank Posted February 14, 2007 Share Posted February 14, 2007 I tried a valve ajustment for a 6000mi. service and also changed air filter, a fog lamp that burnt out. I went to sync the throttle body and it would not start. battery turns, no spark. I set the mottonic to see but no help any Ideas thanks oh also looked at fuses but seem ok Link to comment
ESokoloff Posted February 14, 2007 Share Posted February 14, 2007 Do you here the fuel pump when you 1st power up? Do you have the RID displayed? Link to comment
Heyfrank Posted February 14, 2007 Author Share Posted February 14, 2007 yes I have both. Link to comment
Mike T Posted February 15, 2007 Share Posted February 15, 2007 Most likely something that happend when you did the valve adjustment. Check the obvious things first. -Spark plug wires connected tightly. -Bike in neutral -Kill switch off -Side stand up Did the valves need a lot adjusting? Did you remove the alternator cover to trun the engine to adjust the valves (if so mabye the HES got wacked out of position). Take one of the spark plugs out and with it connected hold it with insulated gloves or plyers agains the engine to see if it spaks when you crank the engine. Link to comment
Heyfrank Posted February 15, 2007 Author Share Posted February 15, 2007 I turned the rear wheel to get to tdc. I am getting alittle spareattic? spark When held against the engine.the valves were real close to not needing any adjustment Link to comment
mrduck Posted February 15, 2007 Share Posted February 15, 2007 Did you happen to molest either one of the gas line QD's? First time I did mine I just kinda moved them around and then nothing-hauled it all the way down to Pomona and took all of 5 seconds to find and fix! Make sure they're pushed in all the way. Link to comment
Heyfrank Posted February 15, 2007 Author Share Posted February 15, 2007 gas line QD, I dont know what that means but to my knowledge no gas lines were touched I guess I"ll back track but in turning it over as many times I do not smell gas like i think i should. If there is a fuse to run a fuel pump I would like to know which one. plug is dry. Link to comment
mrduck Posted February 15, 2007 Share Posted February 15, 2007 Sorry ,the quick disconnects under the right side tupperware. All I did was to fondle them while the body work was off and that's all it took to disconnect them. No gas will come out as there is a check valve in there.Just be sure they are pushed in all the way as you can't really tell by looking at 'em. Link to comment
Heyfrank Posted February 15, 2007 Author Share Posted February 15, 2007 Wow, your good. It was the quick disconnects . I guess I wiggled them to do something. I did not think I did anything. I would have never thought that. Thanks . Link to comment
GordonB Posted February 15, 2007 Share Posted February 15, 2007 A happy ending, that's what makes this board so useful Link to comment
