just954rr Posted February 1, 2007 Share Posted February 1, 2007 Has anyone installed an oil temp gauge on an R1100s?..if so...can you advise me where to install the sending unit?..thanks Link to comment
ShovelStrokeEd Posted February 1, 2007 Share Posted February 1, 2007 The factory temperature sensor is located in a manifold up above and behind the oil cooler. I would not be surprised to find one there or a plugged hole. Look on the right side of the manifold. If I were going to install one, I would probably do so in the oil sump and use a surface mount right on the aluminum. I would also install a cylinder head temperature sensor or maybe two. You can do that by taking a water temperature sensor and sticking it between the fins. Of course, I kinda like the fact that the 1100S doesn't have one. Don't worry, just ride sounds like a good philosophy to me. Link to comment
SANTA Posted February 1, 2007 Share Posted February 1, 2007 i have a spare vdo oil temp sending unit but really want to install a LCD display instead of the 2" dia round vdo gauge, so where would you plan to install the gauge? Link to comment
just954rr Posted February 2, 2007 Author Share Posted February 2, 2007 i have a spare vdo oil temp sending unit but really want to install a LCD display instead of the 2" dia round vdo gauge, so where would you plan to install the gauge? in one of the blinker pods Link to comment
