New1200RTRider Posted January 31, 2007 Share Posted January 31, 2007 Could someone post the procedures for doing the TB Sync. I was just reading a post about some people unplugging the stepper motors and some don't. Thanks Link to comment
Ken H. Posted February 1, 2007 Share Posted February 1, 2007 Step 1. Decide whether or not you are going to unplug the stepper motors. Step 2. Do what you decided in step 1. Step 3. Adjust the right side throttle cable for best sync above idle. Step 4. Reverse what you did in step 2. Step 5. Ride, enjoy! It's really that simple! Link to comment
Jim VonBaden Posted February 1, 2007 Share Posted February 1, 2007 Ken is right, but for the people still uncomfortable doing it "blind", I am making a tutorial this weekend for how to do it. I will post it when it is done. Jim Link to comment
g_e_young Posted February 1, 2007 Share Posted February 1, 2007 Ummm, can you please explain which nut does what on the cable? I did my 1150 20 times with no problem, but I can't quite make sense of the nuts on the 1200 throttle body. Thanks. grant- Link to comment
BucksTherapy Posted February 1, 2007 Share Posted February 1, 2007 When you do the sync above idle is there any recommended RPM you should sync at? Link to comment
Boffin Posted February 1, 2007 Share Posted February 1, 2007 When you do the sync above idle is there any recommended RPM you should sync at? I pick my usual cruising RPM as that is where the engine spends most of its time. Link to comment
Albert Posted February 1, 2007 Share Posted February 1, 2007 Jim, That sounds great! I really look forward to your "documentaries". They are invaluable. Thanks in advance. Link to comment
Ken H. Posted February 1, 2007 Share Posted February 1, 2007 When you do the sync above idle is there any recommended RPM you should sync at? The 'official' procedure is just off of idle, 1500 RPM or so. The theory being that once the cables have started pulling open the TBs, that is all that matters. Other RPMs will follow. And doing it at lower RPMs does help avoid the overheating issue you have to watch so carefully when running a stationary boxer at high RPMs. However as Andy mentioned, so people feel they get better sync by doing it at the higher RPM they most often cruise at. Bottom line, try it both ways and see which results you like better. Link to comment
Marty Hill Posted February 1, 2007 Share Posted February 1, 2007 The 'official' procedure is just off of idle, 1500 RPM or so. The theory being that once the cables have started pulling open the TBs, that is all that matters. Other RPMs will follow. And doing it at lower RPMs does help avoid the overheating issue you have to watch so carefully when running a stationary boxer at high RPMs. Ken, I've never heard the above before. Always do mine at 3.5k or so. Used cooling fans at first but do it so fast now that I don't bother with fans/never had a heat problem with the GS's. Link to comment
keithb Posted February 1, 2007 Share Posted February 1, 2007 When we synced my TB on my 05 RT at the SoCal tech day I think we used 4000 rpm's as the barometer which is about average cruising rpm's. Link to comment
g_e_young Posted February 1, 2007 Share Posted February 1, 2007 The best way is to attach your twinmax to your tank bag and go riding at "criuse speeds" and observe your synch settings. That way you test at cruise speed, under laod, and have plenty of cooling. Plus you have an excuse to do more riding! g- Link to comment
Marty Hill Posted February 1, 2007 Share Posted February 1, 2007 And then you reach down and adjust on the fly? Link to comment
g_e_young Posted February 2, 2007 Share Posted February 2, 2007 I ride two up with my wife and let her hang over the side and do the adjustment as I shout to her what the Twinmax is showing. g- Link to comment
Marty Hill Posted February 2, 2007 Share Posted February 2, 2007 I'll be out that way in a couple of months. I'd love to watch. Link to comment
Ken H. Posted February 2, 2007 Share Posted February 2, 2007 And then you reach down and adjust on the fly? Silly rabbit, those tricks are for kids! Ride, observe, stop, adjust, ride some more, observe some more, repeat. Link to comment
