moshe_levy Posted January 29, 2007 Share Posted January 29, 2007 All- Perhaps with too much time on my hands this weekend, I finished up a full review of my RT's upgraded horn system, which now consists of 2 Stebel Compact 2-tone Nautilus Air Horns. The test is complete with decibel ratings of the before and after, as well as some stock vehicles for reference. There's a video file too so you can hear it for yourself. See http://www.mklsportster.com/r1150rthorn.htm -MKL Link to comment
E30TECH Posted January 29, 2007 Share Posted January 29, 2007 That is wild! Thanks for sharing. Now I have to go back and read the Oilhead Chronicles Link to comment
tjsven Posted January 29, 2007 Share Posted January 29, 2007 Very Nice... Your pulsing headlight put me in a trance... Link to comment
E30TECH Posted January 29, 2007 Share Posted January 29, 2007 Very Nice... Your pulsing headlight put me in a trance... Me too, but the horn snapped me out of it Link to comment
glockster Posted January 30, 2007 Share Posted January 30, 2007 Impressive! Thanks for the insight. Curious, if only installing one of the horns, is using the supplied relay still suggested or is the BMW wiring and relay sufficient? Link to comment
NoHeat Posted January 30, 2007 Share Posted January 30, 2007 Very nicely written, Moshe. Did you find that the larger horns interfered with the mounting of the PIAA 1100x lights? I ask because your PIAA 1100x lights are also located near the oil cooler. When I installed my 1100x lights (using the PIAA-brand mounting kit) the real estate right there was so crowded that I had to remove the stock horns temporarily (as per the PIAA instructions) to make room for the light installation, then I reinstalled the stock horns. Link to comment
moshe_levy Posted January 30, 2007 Author Share Posted January 30, 2007 Impressive! Thanks for the insight. Curious, if only installing one of the horns, is using the supplied relay still suggested or is the BMW wiring and relay sufficient? One horn can run on the stock wiring & relay - however, you are then powering the horn from the smallish 18 gauge wiring rather than from the 12 gauge. Using the stock wiring cuts the job time in half, though. Whether those extra few dBs are worth it is your call. -MKL Link to comment
moshe_levy Posted January 30, 2007 Author Share Posted January 30, 2007 Very nicely written, Moshe. Did you find that the larger horns interfered with the mounting of the PIAA 1100x lights? I ask because your PIAA 1100x lights are also located near the oil cooler. When I installed my 1100x lights (using the PIAA-brand mounting kit) the real estate right there was so crowded that I had to remove the stock horns temporarily (as per the PIAA instructions) to make room for the light installation, then I reinstalled the stock horns. My PIAAS are mounted on an ESY-shelf under the oil cooler. I did have to loosen the shelf to get access for my hands during the horn install, but after I was done, there was no interference whatsoever. -MKL Link to comment
