Bud Posted January 26, 2007 Share Posted January 26, 2007 Here is the setup under the seat. AutoSwitch and light relay inside the fuse box. Blue Seas 6 circuit box and relay to powerit on lid of bike fuse box. [/img] And here is what the results look like. eMp brackets. Great fit and finish. Thanks Pat. Hella FF 50's Link to comment
W8NONU Posted January 26, 2007 Share Posted January 26, 2007 Looks like a nice clean install. Link to comment
jerseygeorge Posted January 27, 2007 Share Posted January 27, 2007 You may have said this before, sorry if I missed it. How low will the seat go with the Blue Sea Fuse box mounted where you did. I like the location, just wondering how low the seat will go. Thanks. Link to comment
Bud Posted January 27, 2007 Author Share Posted January 27, 2007 You may have said this before, sorry if I missed it. How low will the seat go with the Blue Sea Fuse box mounted where you did. I like the location, just wondering how low the seat will go. Thanks. If you need the seat lower than the high position, you would have to mount the box on the air cleaner cover. Where I have it mounted the seat has to be in the highest position. Link to comment
St_Louis_Don Posted January 27, 2007 Share Posted January 27, 2007 Bud, Nice clean job. George, I mounted my BlueSea on the air box. The seat will not go into the lowest position. Since I'm 6'2" that didn't bother me. Link to comment
jerseygeorge Posted January 27, 2007 Share Posted January 27, 2007 Bud, Nice clean job. George, I mounted my BlueSea on the air box. The seat will not go into the lowest position. Since I'm 6'2" that didn't bother me. Thanks, I am going out to do that today (on the air box). I believe that I will have to move the diagnostic plug in order to do that (2004 R1150RS). BTW - What size wire did you guys use from the battery to the Blue Sea? Link to comment
St_Louis_Don Posted January 27, 2007 Share Posted January 27, 2007 Hey George, I used 8ga. I didn't have to move the plug. I put the relay on the side of the seat steps. Link to comment
jerseygeorge Posted January 27, 2007 Share Posted January 27, 2007 Thanks, and btw 9'5wt sage, 8'6" 4wt winston! Link to comment
St_Louis_Don Posted January 27, 2007 Share Posted January 27, 2007 Thanks, and btw 9'5wt sage, 8'6" 4wt winston! I knew that would get a "rise" out of someone. Link to comment
