DaveWL Posted January 23, 2007 Share Posted January 23, 2007 I'm about to pull the gearbox from my '04RT and am concerned about bending the pushrod. How far "straight back" does the gearbox have to go before the pushrod clears the clutch area? Thanks. Dave Link to comment
Boffin Posted January 23, 2007 Share Posted January 23, 2007 I'm about to pull the gearbox from my '04RT and am concerned about bending the pushrod. How far "straight back" does the gearbox have to go before the pushrod clears the clutch area? Thanks. Dave If you remove the slave cylinder you can grasp the end of the pushrod with some grips and pull it out before separating the box from the engine, removing all risk. To simplify gearbox removal/refitting you should make up some guide rods to replace two of the gearbox maounting bolts. Obtain 2 M8 x 110 mm long bolts. Cut off the hex heads and slot the end of the bolts. These will guide the box in and out - and would also protect the pushrod. Andy I just checked my files and corrected the bolt size to 110mm Link to comment
Bob_Minor Posted January 23, 2007 Share Posted January 23, 2007 Use some guide pins, they're easy to make and ensures you won't ruin the clutch rod. This thread calls for 110mm bolts, think I used closer to 160mm which was overkill. guide pins Link to comment
DaveWL Posted January 24, 2007 Author Share Posted January 24, 2007 Thanks guys. Great comments. Dave Link to comment
Ken H. Posted January 24, 2007 Share Posted January 24, 2007 As Andy said, remove the push rod before removing the transmission, reinstall it after putting the tranny back in. Link to comment
DaveWL Posted January 25, 2007 Author Share Posted January 25, 2007 Last night I removed the slave and tried to pull out the pushrod. It wouldn't budge, even with a substantial amount of effort. The reason I'm doing the teardown is because I have some sort of clutch problem which I'm investigating. I'm beginning to think that the pushrod has some damage. So, back to my original question, have far back does the gearbox have to be pulled before its clear and can be dropped to the floor. Thanks Dave Link to comment
Bob_Minor Posted January 25, 2007 Share Posted January 25, 2007 I would guess about two inches. But do yourself a favor and make the guide pins. I've done it both ways and it's so easy to take it out and put it in with the pins. Without them it is a very clumsy process. Link to comment
DaveWL Posted January 25, 2007 Author Share Posted January 25, 2007 Perfect. Thanks again. Link to comment
