mrduck Posted January 22, 2007 Share Posted January 22, 2007 I want to wire the power directly in and not use the big plug(cigarette lighter style)BUT the power goes from 9-14v in to 5.2 out.So somewhere in the plug the voltage is getting reduced. So now what?? Link to comment
Ken H. Posted January 22, 2007 Share Posted January 22, 2007 Check out the adaptors mentioned in this thread - 6v for XM Link to comment
St_Louis_Don Posted January 22, 2007 Share Posted January 22, 2007 There is a voltage reducer thingy in the plug. I’m too cheap to buy any kind of adapter. So… I cracked open the plug, clipped the wires off the terminal ends, soldered on a new length of wire, fed that through the end of the plug where the terminal end was, snapped the plug back together and taped it up real good, then ran the new length to the aux fuse block I had installed. Works like a champ and didn’t cost me a dime. BTW I have the XM SkyFi Link to comment
GelStra Posted January 22, 2007 Share Posted January 22, 2007 Nando did exactly the same thing for me with the wires. Hid the ugly plug thingy under the tupperware. Link to comment
Firefight911 Posted January 22, 2007 Share Posted January 22, 2007 Pull the plug apart, get a job box from Radio Shack, solder your power connections in, close up the job box with the power transformer in, and voila!! Done. That's what I did for my XM Radio hook up on the ST. Hid the job box under the fairing and wired direct into the switched power lead. Link to comment
St_Louis_Don Posted January 22, 2007 Share Posted January 22, 2007 Pull the plug apart, get a job box from Radio Shack, solder your power connections in, close up the job box with the power transformer in, and voila!! Done. That's what I did for my XM Radio hook up on the ST. Hid the job box under the fairing and wired direct into the switched power lead. Wel, sure you could do that. But a job box cost, what? A $1.59. OUCH! Link to comment
GelStra Posted January 22, 2007 Share Posted January 22, 2007 Wel, sure you could do that. But a job box cost, what? A $1.59. OUCH! That's true. Anything BMW should cost $159.00. Link to comment
rdsmith3 Posted January 23, 2007 Share Posted January 23, 2007 I used to have a Roady2 in my Roadster. The transformer was in the cigarette plug. It stepped it down to 5 volts. I bought a cigarette lighter socket from Radio Shack for about $5. I wired that to a switched power source, then I plugged the Roady2 into that socket. I duct taped the plug and socket together and put it near the battery. It worked well for me. Link to comment
truckdogg4 Posted January 23, 2007 Share Posted January 23, 2007 I picked up a wiring harness that included everything needed to adapter the XM Roady 2 to my bike. I paid something like $9.99 for it. I believe I found it on XMstore.com. Works great. It's hard wired to my 02 RT Link to comment
mrduck Posted January 23, 2007 Author Share Posted January 23, 2007 Well thanks to all! Now I'm no electrcian but I do work with some very good ones. I've popped the plug apart and will have the leads installed shortly. Ya gotta love this site Link to comment
bmwmick Posted January 24, 2007 Share Posted January 24, 2007 I've done that for several friends. Pull the cigarette lighter adapter apart (Roady2) and remove the circuit board. Solder on some wires to feed it 12V (switched only as this adapter WILL drain your battery) and then slip the circuit board in a piece of heat-shrink tubing. Once you shrink it, it will mount just about anywhere and it's pretty waterproof. Mick Link to comment
St_Louis_Don Posted January 24, 2007 Share Posted January 24, 2007 I've done that for several friends. Pull the cigarette lighter adapter apart (Roady2) and remove the circuit board. Solder on some wires to feed it 12V (switched only as this adapter WILL drain your battery) and then slip the circuit board in a piece of heat-shrink tubing. Once you shrink it, it will mount just about anywhere and it's pretty waterproof. Mick Wow, heat shrink around the cb, that beats the way I just wrapped the plug in tape. I'll have to add this to my "To Do" list. Thnx Link to comment
bmwmick Posted January 24, 2007 Share Posted January 24, 2007 It makes a neat little 'almost' flat package. Mick Link to comment
bikerscooby Posted January 24, 2007 Share Posted January 24, 2007 This will be my next project if I ever get the brakes fixed and have any money left. Anyway, I have 2 old Delphi SkyFi XM units, one I sometimes use on my F650CS, and would like to set up the R1150RT-P to be able to use it too. The 1150 has speakers but no stereo, and I don't want to buy a whole stereo system for it just to use as an amp. I really just need a 2-channel 12V amplifier with a volume control that will accept the XM signal and drive the speakers at an appropriate level. I was considering taking the parts from a $39 "Sonic Impact 5066 T-Amp" and try to mount it somewhere in the fairing so I could access the volume control. But this amp only outputs 15W, and I'm not sure if that's powerful enough, as the SkyFi output signal is quite weak. How many output watts does the BMW stereo (or others people are using) put out? Link to comment
St_Louis_Don Posted January 24, 2007 Share Posted January 24, 2007 I use a MixIt as the amp for my XM. Not sure if it would power speakers. Link to comment
bmwmick Posted January 24, 2007 Share Posted January 24, 2007 I believe the stock BMW radio in my R1100RT is 10W per channel RMS into 8 Ohm speakers. Mick Link to comment
Mark K Posted January 25, 2007 Share Posted January 25, 2007 I bought a cigarette lighter socket from Radio Shack for about $5. I wired that to a switched power source, then I plugged the Roady2 into that socket. I duct taped the plug and socket together and put it near the battery. It worked well for me. Me too Link to comment
