Bud Posted January 20, 2007 Share Posted January 20, 2007 So I have my lights wired up to the relay. They work just fine when I apply voltage to the relay. Bought an Autoswitch so I could us the turn signal cancel to turn the lights on and off. The auto switch works if I manually ground the trigger wire. Followed the instructions and wired the trigger wire to the brown/white wire going to the signal relay which is supposed to go to ground when the cancel switch is held in. Doesn't work. So any ideas since I know the lights work and the autoswitch is switching when I manually put the trigger wire to ground. Perhaps the brown/white wire isn't the correct one? Link to comment
